Originally Posted by
bfreedma
buddahead
Who are you to say what one can hear in different amps.And how are your ears better.Their is huge difference in integrated amps.If you can't hear the difference in a Nad from a Bryston then you have bad hearing like many here.Allways try different electronics with your speaker
Imagination is a wonderful thing.
Besides insults and your unsubstantiated opinions that fly in the face of accepted science, any actual evidence that you care to produce?
By chance I found what well might be the testing by buddahead that led to the conclusions that he has posted here:
buddahead
Been breaking in my New Music Hall A70.2 integrated.It replaces my 14 year old Rotel integrated. After listening to the Creek 'Exposure'Krell' Rega I chose the MH for its build quality and all around sound.They all sounded good with my MA rs'6. The difference from my old Rotel is quite unreal.This integrated like most Higher End integrated never sound loud.When you turn the volume up you hear each piece of the music get more detail but not excessive volume.Their is no Fatigue.I like the exposure also.Al of these newer Integrated were so much better than the Rotel that their is no comparison.The MH has such a open soundstage and imaging.Plus the MH has 125w into 8ohms.Plenty of power for down the road new speakers.It also has 2 separate mono blocks each with its own Transformer. I like the volume display that goes from 0 to 80 so you can put the volume level at the exact same spot when testing new equipment.I just wished I had gotten this amp sooner if I would have known it would be this much better.Roy Hall did a fine job of this amp and it includes a decent Phono stage for my MH TT'I have yet to use this.Will post on that later.
And let me say some who post here and always say all amps sound alike have no clue. I feel sorry for them.All of these amps I tested had their own sound. And the difference between these higher end integrated and HT recivers are not even funny for 2 channel setups.I own 2 nice HT recievers and they do not come close to this MH integrated.For those who appreciate high end audio please feel free to comment.Thanks Bob
Now, lets try to understand where Bob is coming from:
buddahead
Been breaking in my New Music Hall A70.2 integrated. It replaces my 14 year old Rotel integrated. After listening to the Creek 'Exposure'Krell' Rega I chose the MH for its build quality and all around sound.They all sounded good with my MA rs'6.
One could intrepret the above as saying that "all amps (that I tested) sounded pretty much the same (good).
buddahead
Given that the old amp was 14 years old and was in unknown technical condition, I have no argument with that!
buddahead
This integrated like most Higher End integrated never sound loud.When you turn the volume up you hear each piece of the music get more detail but not excessive volume.There is no Fatigue.
One of the things that one learns in blind tests is that the above pleasurable sensations are the same with a great many far less expensive amplifiers.
buddahead
I like the exposure also. All of these newer Integrated were so much better than the Rotel that their is no comparison.
Again given that the old amp was 14 years old and was in unknown technical condition, I have no argument with that!
buddahead
The MH has such a open soundstage and imaging. Plus the MH has 125w into 8 ohms. Plenty of power for down the road new speakers. It also has 2 separate mono blocks each with its own Transformer.
The dual monoblock feature is there, but again without blind tests, how would one find out that it is usually irrelevant to sound quality?
buddahead
Buddahead apparently does not know that equipment itself often has different amounts of internal gain, and volume level settings on the amplifier do nothing to equalize that.
buddahead
We now know that Buddahead does not know the truth about how to do level matched blind tests. He thinks that he has done good enough level matching when he probably hasn't.
buddahead
All of these amps I tested had their own sound. And the difference between these higher end integrated and HT recivers are not even funny for 2 channel setups I own 2 nice HT recievers and they do not come close to this MH integrated. For those who appreciate high end audio please feel free to comment.Thanks Bob
The above would appear to be a classic example of someone who collects flawed information and uses it to reinforce his prejudices.
