AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › HDMI Controll Question
post #1 of 5
I have recently purchased a Pioneer VSX-1121-k AVR. I am pairing it with a Samsung LN-S4695D LCD TV. I am having two perplexing problems.
1. When I turn off the TV, the AVR goes into standy-by (shuts down). I have HDMI controls set to "OFF" in the VSX-1121-K. I am not able to find any information about HDMI controls for the Samsung TV. As it stands now I cannot listen the the radio, Pandora, internet radio, etc... unless the TV is turned on. Any advice would be appreciated.
2. The second problem: I have the VSX-1121-K setup as 5.1 plus Zone 2. I was very interested in the ability to have potentially different sources piping audio to different parts of my home. All audio options work fine. But I cannot hear my DirecTV satellite STB (HR21-200) on Zone 2. I figured that maybe it had to do with Surround Sound so I forced the AVR into Stereo mode. Still nothing on Zone 2. Again, any advice would be apprecieated.
I am less than a novice on all things AV - I could sure use some help from the experts on this forum.
Thank you
post #2 of 5
problem 1 is probably KURO link. try disabeling it.
prob 2 i dont know.
check out this thread
http://www.avsforum.com/avs-vb/showthread.php?t=1330154
post #3 of 5
1. Samsung CEC is called Anynet or Anynet+ - look for and Disable it on the HDMI Input. Once disabled repower the system.
2. Zone 2 will usually only support 2 channel Analog Sources! Install an additional 2RCA to 2RCA cable between your HDMI Source and the AVR and you should be sorted for Zone 2 audio!
Joe
post #4 of 5
Thank you to both Skinney6 and Joe Fernand. MIssion accomplished! I really appreciate your knowledge and willingness to share it with me.
post #5 of 5
Cheers - great you got it sorted.
Joe
