I am laughing at most of this stuff, why, because do you guys even know what frequency response you are hearing? You listen to speakers in a room and say it sounds good or bad and then listen to another set in the same room(or not) and then compare. Do you even know what the response is that you like? How do you know it is flat at your listening postion? I really don't care what the response is outside because once you put it indoors all bets are off. Have you even tried comparing the speakers in the same location and get the response at the seats the same? Once you get the response flat at the seats you will be surprised how much power one uses for reference levels and the more sensitive speaker will still sound more dynamic. A 91 dB speaker can play reference because it only needs about 100 watts at the LP from 7 feet. If the speaker can only handle 150 watts or 200 watts it only has 3 dBs of headroom so it may not be distorting but it will be compressing. If it can handle 400-500 watts than it will handle compression better while at reference at 7 feet.
Also, how many times I see friends look at speakers and say which one sounds better because of looks, drivers, name or whatever. They already made their decision without ever hearing them. This is why I run blind tests all the time and get honest feedback. The funny thing is I have had $3500 per speaker to $250 per speaker(DIY) and from listening everyone always chose the $3500 speaker when sighted. Once I put them behind the screen the DIY speaker all of a sudden was the best, go figure. Actually one person still picked the $3500 speaker but that speaker was a very good speaker and high sensitivity(2nd best for movies)
