AVS › AVS Forum › Video Components › Home Theater Computers › Best pc budget pc for running plex or xbmc?
post #1 of 4
I'm sure this has been answered before, but I'm looking for the best bang for my buck. I wanted to get an affordable htpc that would run plex and play x.264 blu-ray rips without any problems. I would go with the mac mini, but I can't swallow the $600. Anything at Best Buy right now that would work for around $300?
post #2 of 4
anybody?
post #3 of 4
Originally Posted by jbn008 View Post
anybody?
Build your own.
post #4 of 4
Maybe just to elaborate a tiny bit .
You really should read through the guides in the stickies . There is a ton of free info and some really kick butt paid stuff to .
Just a bit of friendly advice . I mean this with the most positive intentions.
This is the htpc section of the avs forum . To ask an enthusiast group of folks what is the hot thing at B#$t B&* right now will most likely not garner a lot of help
