Originally Posted by Nuance
Controlled directivity designs aren't the only ones that sound great, measure great and actually sell. You're like a broken record man.
Since you like to bash every design out there other than controlled directivty (which don't all sound and measure good), where are your line of speakers? I'd like to try them out. You seem to think you're an expert, so where is your award winning design? I'd love to give it a listen. Will you be at RMAF or any of the audio shows? I think I already know the answer...
Nuance, what you are missing is this. It's not that uncontrolled directional designs don't sound good. The opposite. Many do. The problem is when you place them in rooms. Real rooms, like your living room. You will get a far greater degree of variability than the controlled response designs. That's precisely what Toole et al found. Much greater consistency of "good sound" perception, room after room, with uniform directional characteristics. Less variability.
You mention shows. Read the comments on my type of speaker in mid to shoe box size rooms. Do you see remarkable consistency or variability of perception? Now contrast that to say a cool shaped gorgeous wood finish standmount designed by a weatherman, with all the visual cues to arouse the RAALtarboys. Sounds spanking great in that huge room there. Oh but wait, what happened here to mess up the sound in this smaller room?? Where did the magic go? Was it the amp? DAC? Cables? Burn in? "Synergy"?? No wait, it was the room! That SOB crappy room ruined it. Or was it? Same sized or even smaller/worse room...yet I sailed through unscathed. Coincidence? Luck? Hmmm.
Come up to Capfest and see if my luck hold up. Uniform polar field and 97db will be the lower sensitivity design.
If the sound sucks I'll blame the wires
.cheers,
AJ
p.s love Rutgars pics of those huge pretty speakers....and that stuff stuck on the walls
(no comment on those lifter thingies)
