Figured I post this in case anyone else wants to flash the bios of their motherboard.... and doesn't have a floppy drive!
If you have a USB jump drive you are set:
There is a utility to turn your USB drive into a 3.5 floppy is right here:
http://files.extremeoverclocking.com/file.php?f=197
At the top of the page is the file (win98boot) you will need to make the usb drive bootable.
Here is a quick youtube clip to show how easy it is to make a bootable usb: http://www.youtube.com/watch?v=J9f0J7OxW7c&feature=related the link in the description is dead... use the links I've provided to download the software and boot files.
Once you have done this... just drag your bios utility and firmware to the usb... You will then have to set the bios to boot from the USB ... then run the bios executable form the c:> prompt.
