AVS › AVS Forum › Video Components › Home Theater Computers › Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative?
Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative? - Page 61
post #1801 of 2256
The molex plugs on the backplane are doubled so that a dual PSU setup can provide power easier (split or 1 instead of the other).
So no, you only need 1 of the 2 molex plugs connected unless you really want both plugged in due to some kind of OCD need or having dual PSUs. If you have a power tester you will find the pins have continuity between the 2 connectors.
post #1802 of 2256
post #1803 of 2256
I could be wrong but aren't the two (sets of 4) molex plugs required for the 24 drives that they would be providing current for? Otherwise you could have enough voltage drop on the single cable, especially when all drives spin up together, which can cause problems.
post #1804 of 2256
I only use a single molex per backplane on a single rail PSU with no issues. The double molex are for dual PSUs.
post #1805 of 2256
Just ordered a few of these to help make a 140mm wall of fans and thought id share these for others who are interested
http://www.frozencpu.com/products/16145/slf-11/Akust_Adjustable_Magnetic_Fan_Bridge_Mounting_Kit_BK00-0107-AKS.html
post #1806 of 2256
OMG DO I LOVE YOU, i just changed this because i had a ton of molex plugs squeezed in there.
post #1807 of 2256
You guys are going to hate me and my issues smile.gif . I'm new to servers but not new to building computers and have a problem I hope you can help with. I installed a new PSU to replace the dual PSU that the server came with and everything seemed to be working fine. Only now that I have tried to get things going only half or less of the hard drive slots are working. They were all working prior to installing the new PSU. I checked all of my hard drives and they work fine. I also checked the SATA cards and cables and they appear to be working fine as well. It's like some of the individual slots have died. If your facing the front of the server the top left and bottom left slots work but none in between. Four slots work on the stack all the way to the right. Any ideas? Thanks smile.gif
post #1808 of 2256
I would guess bad molex connections or a flakey back plain. Did you hear the drives not spin up, or is it just no LED lights on the front.
post #1809 of 2256
Been checking the bios and initial sequence with only a couple drives showing. Same drives do not show in unraid either. You can take the drives and put them into a known working slot and they will show so I know its not the drives.
post #1810 of 2256
It could be the backplane. I killed my backplane with a static shock. The LED lights wouldn't come on and some drive slots became dead (fortunately no dead drives!). I bought a replacement on ebay for $40.
post #1811 of 2256
rc05, your probably right. That was my thought too (unfortunately). Have to check and see if I can find a replacement.
post #1812 of 2256
If anyone is looking for either the original power supplies, or the power backplane for the SM servers PM me.
post #1813 of 2256
Yes, this is all true and confirm 3TB support. The thing that is strange is that the cards recognize the drives as 2TB at boot up in the BIOS, but show as 3TB correctly in Win7. I used the drivers Killroy posted, but do not recall if they showed up correctly prior to install. I thought I would post this since the 2TB boot up threw me since I have never seen it show up differently in the OS.
I have a 1TB OS drive directly connected to MB SATA port, but shows up as 500GB. Probably need to upgrade the BIOS.
post #1814 of 2256
I have a Intel version Mobo if someone is interested in doing a 48 bay version.
post #1815 of 2256
Ok, so I got a good deal on a HX850 and ran with it! The cables I posted before did not fit the length as each was different length. Instead I ordered CBL-0237L which should work just fine. I also accidently purchased a couple extra dell h200 on ebay so if anyone is interested in either those or any of the old server parts just shoot me a pm please. Once I get the cables I will have everything ready to go. I will be posting pics as soon as I get it wired up. Thanks again everyone for all your awesomeness!
post #1816 of 2256
Something to check for is to try to isolate the problem down to 1 component. For instance you have confirmed that the hard drives aren't the problem as they do work in some spots.
Other sources of issues could be:
  1. Sata cable not quite plugged in
  2. Power not quite plugged in
  3. Sata cable not plugged into SATA card
  4. Bad sata cable
  5. Bad port on the SATA card
Any are certainly possible so a good test would be to reseat the cables and try. Then if that doesn't work, try a known good cable/card combo and transfer it to one of the not working bays (just incase it may be the cable or something like that).
If the known good setup in a "bad" bay doesn't work then you have a fairly solid case on a broken backplane.
post #1817 of 2256
I bought one of these servers and want to add another processor. My server was an amd 1.8 quad with 8gb ram. Is this the right processor to purchase as a second cpu,
Clock Speed 1.8 GHz
CPU Socket Type Socket F (1207)
Multi-Core Technology Quad-Core
TDP 55 W
post #1818 of 2256
Clock Speed 1.8 GHz
TDP 55 W
That should work although matched pair would be preffered.
post #1819 of 2256
If anyone is looking to upgrade from the stock TAMS configuration, I have the following:
CPU/FAN/RAM SOLD
qty (2) AMD 2419 hex-core cpu
qty (1) socket F cpu heatsink/fan
$20 + shipping for both cpu's and heatsink/fan
qty (18) DDR2-667 2GB ECC ATP AH56K72J4BHE6S
$3 each/$45 all + shipping
qty (3) SAT2-MV8 REV:3.00 PCI-X HBA
$15 each/$40 all + shipping
qty (2) Intel PRO/1000 MT PCI-X dual nic
$15 both + shipping
I used this setup for a bulk transcoding project, and am now re-configuring the chassis as a backup fileserver.
The nics were used with SMB multi-channel to a storage array.
The cpu's/RAM/NICS ran 24-7 under heavy load with no problems.
I verified all ports worked on the HBA's upon receipt, in storage since then.
Please PM with shipping info if interested.
Edited by Poto - 9/16/13 at 3:35pm
post #1820 of 2256
That looks great. May I ask where you were able to get the rails??!!!
Saw one "MCP-290-00014" on Ebay for $150 + $30 local shipping (California)... way overpriced and in my opinion not worth it. I'll keep looking.
I set an eBay search and just waited. One showed up for $35 but with almost the same amount in shipping. So about $70 total.
post #1821 of 2256
If anyone is interested in the 2U unit
http://www.avsforum.com/t/1412640/are-you-looking-for-a-less-expensive-norco-4220-4224-alternative/630#post_22307860
I think I am just going to sell mine and possibly use this case in the future when I need it. I already replaced the fans with Arctic Cooling F9 fans and still have the old ones. As it is, I was only going to end up using the case anyways and that one is quite a bit shorter.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147165
PM me if interested in the whole unit or the parts
post #1822 of 2256
Server up and running! I got a good deal on the 8087 cables with sideband from smci_express on ebay, they sell on amazon as well but you can email (ybchin@yahoo.com) them and try to get better prices (I told them I would be sending people so feel free to mention barry sent ya!) they worked with me on everything and I just noticed they have the rails as well. I got a decent discount on the cables and hope they can drop the prices on the rails some as well. Pics coming soon and if anyone needs any of the old parts from the amd supermicro server or I also won a couple to many auctions for dell h200 perc let me know! Also check out frozencpu for magnetic fan mount kit, I used one for my pci cards and a set for my 140mm fan wall just to help keep it in place.. also for those of you who want more internal usb I picked up one of these StarTech.com 2 Port USB Motherboard Header so I can have a usb for esxi and one for unraid inside server, so I will have a spare usb for future even inside!! pics to be posted next!
Edited by BarryHalls - 9/17/13 at 4:59pm
post #1823 of 2256
Okay now with the pics!
I got all the wiring in as good as I could for the time being (made it a bit nicer with fans being away from wires since photos were taken) All in all tho I am satisfied! If anyone has any questions please let me know id like to help pay it forward anyway I can!, again I want to thank everyone here who already did all the work and research behind my current build... you are all awesome!
post #1824 of 2256
The heatsink fan on one of my Xeon 5130 is making some seriously nasty sounds. Anyone know of a good replacement or a good mod to add a generic one to quiet it down?
post #1825 of 2256
That's a nice build! Was that based on the Amd supermicro server? Two things I woul like to know is how effective the 140mm fans for cooling and the power consumption of the components since you replaced the MB and PSU.
post #1826 of 2256
Gents - I will have an 846 Chassis available by the end of the weekend. Mine is the version with the 8087 port instead of the 24 Sata ports. I'll include an LSI PCI-E JBOD card with an 8087 port and the necesarry cable to go with it. I'll have details and photos once I'm done moving data off of it.
post #1827 of 2256
You're planning to sell the chassis with some hardware? Send me a PM on what you plan to ask for it. May not be until next week until I can get it though but I am interested, as I am looking to get one for my brother. Look forward to the pics.
post #1828 of 2256
Correct, I'll have pics and stats for you by the end of the weekend.
post #1829 of 2256
My first Norco case (bought early 2008) is finally dying (one of the backplanes is dropping out) so I shelled out for another AIC box. Maybe I will finally try that 8U mod.
post #1830 of 2256
Sounds great, look forward to it!
Not bad for 5 years if use! The AIC boxes are fairly cheap, can easily have a good number of server boxes in no time. But of course that will mean you will have to do the mods again to make it quiet. I may plan to mod my AIC box for quieter operation as well but will take some work. An 8U mod will be quite a beast!!
