Originally Posted by
Litlgi74
I am so glad that everyone is happy with there machines so far.... I would suggest you swap out the 80mm with quieter fans before replacing the the fan wall with 120mm fans.
Also... if you go into the bios and advanced>hardware monitor> you can generally adjust the fan speed.... choosing Server... sets the case fans to the speed of the cpu. This makes the machine even quieter.
Yup, good point. I've seen the choices of "default", "server" and "workstation". Right now at "workstation", fans are at about 4500RPM.
That looks like it will do all of the same stuff, although it looks like it needs a web client to be installed on the OS running on the SM. I'm using OpenIndiana and didn't see a client listed, also I'm perfectly happy with IPMIView as I was able to:
1. See sensor readings
2. Control the console
3. Power-off / Power-on
So happy with this thing, can't even describe it. Thanks again sir!!!
