You can always just undervolt the fans rather than buying new ones.Originally Posted by OneFast3
This is on the supermicro case. I just dont seem to like this H8DM8E motherboard at all. Was hoping to put the bigger 120mm fan wall in so if i need more cooling I can run them faster but no, the motherboard runs them full speed no matter what I do. Is their a work around for this? I tried speedfan but to no luck at all. They are pwm fans and tried to connect to cpu fan for control. Have tried settings in bios at server and workstation. Just wants to run them at 2k (full speed) at all times. Did not try running on the backplane but i'm sure that runs them at full speed too.
Guessing my only option is to replace the fans with ones that are slower and at a sound level I can tolerate. Sucks having everything in 1 room.
Wait, you're not talking about the original fans, are you? Those can't be undervolted enough to run quiet.
, done. easy to remove
hhaha....
