AVS › AVS Forum › Video Components › Home Theater Computers › Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative?
Are You Looking For A Less Expensive Norco 4220 / 4224 Alternative? - Page 34
post #991 of 2256
Originally Posted by captain_video View Post
I'm going to try and drill out all the rivets in the way within the next week or two. This will be my first time drilling through steel. What kind of oil lubricant should I use for the drill bit?
post #992 of 2256
If you're only drilling out a few rivets then you really don't need any special lubricant. High speed steel bits are the most common and the cheapest, but they dull the quickest. Chances are they'll be fine for drilling aluminum rivets. Otherwise, I'd recommend cobalt or other high quality bits like titanium for the job. You'll probably need a 1/8-inch bit, but check the actual rivet for the proper size.
post #993 of 2256
Originally Posted by cshaw88 View Post
Anyone have a suggestion for a 500w PSU than could fit (or at least come close to fitting) into a 2U?
I kicked around the idea of just kludging together a 500w PSU that I would just mount externally, or have it stick out of the top of the server. My 2U is out of sight, so it doesn't have to win any beauty contests.
http://www.seasonicusa.com/2u.htm
I would grab one of the gold rated ones on ebay.
http://www.ebay.com/itm/Seasonic-SS-400L2U-400W-80-Plus-Gold-EPS12V-2U-Server-Power-Supply-/200816537765?pt=US_Power_Supplies&hash=item2ec19930a5 $85
http://www.ebay.com/itm/Seasonic-SS-500L2U-500W-80-Plus-Gold-EPS12V-2U-Server-Power-Supply-/200831290112?pt=US_Power_Supplies&hash=item2ec27a4b00 $101
post #994 of 2256
Thanks for the input
post #995 of 2256
those are using 2U PSU standard size.
someone was complaining 2U PSU does not fit... since do not have 2U supermicro, I can not verify....
I use 2U PSU for previous AIC deal.
I measure my 4U micro server. 2U PSU should fit on 4U supermicro . I conclude that the 2U case length is shorten than 4U supermicro case
post #996 of 2256
Originally Posted by Litlgi74 View Post
True! But for a basement or garage... no problem!
My laundry room is about 45² ft, and has it's own air conditioning register. It is by far the coldest room in the house during summer. Even doing laundry a few times a week does not heat it up too much. This is where I'll place my rack. Still have to get (more) power and ethernet in there, but that's a smallish job for my electrical contractor.
post #997 of 2256
Originally Posted by Z-95 View Post
Took some better pics with a real camera:
Nice.
What is the model of the rack? And would it be safe to stack a second one on top?
post #998 of 2256
Just called; they have nothing at the moment. I sent an email and will be added to the waiting list.
post #999 of 2256
Anyone needing a good PSU for these servers should check NewEgg's sale today. They're selling the Seasonic X750 for $99 shipped! That's the best price I've seen on it. I got mine at $120 and I have one running my server in this case. Best power supply I have ever had.
post #1000 of 2256
Originally Posted by wkearney99 View Post
For those looking to find some extra AIC caddies: http://www.ebay.com/itm/AIC-N2-100-20131-Server-Hard-Drive-Caddy-Tray-Sled-RMC2E-/200813192430?pt=US_Drive_Bay_Caddies&hash=item2ec16624ee
I made a lower offer on 4 and it was accepted.
But a month later the seller tells me they couldn't find them (due to a move) and refunded my purchase. Bummer
post #1001 of 2256
You could get fancy if you want and go to the local hardware store and get a bottle of "tap oil" . If it is just a few small rivets I would cheat with some vegetable oil . DRILL SLOW !
post #1002 of 2256
Well, I pulled the trigger on one of the Supermicro 4U servers available on ebay currently, but got them without the trays. TAMS ships the servers in a strong box with excellent foam packaging. Got about 30 new trays off of ebay and newegg to finish it off with some spares.
Would like to thank the OP for making this public.
Now the time is coming to build it up and mod it a bit. I already have quiet Nexxus 80mm fans that I had from another project, so I will swap those in. Got a Corsair 850w PSU from newegg, 16Gb (4x4Gb) from ebay seller (turned out to be Kingston), and a pair of the 4219EE processors from Amazon (a no brainer upgrade at about $10 each even if I do end up doing software RAID). I need to get a couple HSF's for them. Also have a couple of 80G Intel SSD's for OS and possibly ZIL cache (not sure if I will do a ZFS flavor or WIndows/Flexraid).
I did try to order some replacement hard drive controllers, but did not do my homework sufficiently. I ended up ordering a couple 3ware 9550sx-12 controllers off ebay but they don't seem to support >2Tb drives ... a no go for me. So I will see what I can do with the stock hardware. I'm still not 100% positive the stock controllers will work with >2Tb drives, but we will see.
Then I have to start buying drives ... I have a few drives, including a 3Tb, that I can test with in the meantime.
Then ... to ultimately put it to use storing music and movies via ReQuest (which I also don't have yet ... but soon smile.gif)
post #1003 of 2256
Is it one of the Supermicro SC846TQ units?
post #1004 of 2256
Yes ...
post #1005 of 2256
Just curious, where did you find the drive trays and how much did they cost? I checked around and the cheapest I could find them was about $8 apiece. I figured it would cost me about $200 minimum for just the trays. The original server being offered was the same model with all trays included for only $50 more than the one you bought off ebay.
I'm not 100% sure, but I believe the Supermicro AOC-SAT2-MV8 cards that come with the server might support drives >2TB. The Supermicro website doesn't really specify this in the product details but I thought I read about it in a thread here that discusses SATA controllers.
post #1006 of 2256
Also be aware you might not be able to get drivers for that card depending on what OS you're planning to run. I discovered ESXi 5 does not support the card. I replaced them with some IBM M1015 cards; better performance and current driver support. So be sure the controller itself is supported too.
post #1007 of 2256
It should work fine with most Linux distributions as well as unRAID. If you're looking to use it with WHS or FlexRAID running in Windows newer than Win 2K you may be out of luck.
post #1008 of 2256
It took me a few days to read through this thread, but yes, I understood that. I would prefer to virtualize now, not for any real need now, but for down the road when I'm tempted to put another computer for whatever reason in the "server room". To that end I might pick up those m1015's, but how do you get all 24 drives on m1015's? There are only two PCIe slots on this mobo ...
post #1009 of 2256
While I'm not too old to learn a new OS (I've only toyed with Linux), I just don't have the time to put into it anymore. I would prefer to run the new Windows Server 2013 virtualized and FlexRAID for storage. So I will look again at the M1015 solution, but don't have a clue as to how I can get three of those adapters on this motherboard.
post #1010 of 2256
I realize I paid more than everyone who saw this earlier, but I think it's still a good deal. Besides you all did the ground work already, I just spent a few days reading about it cool.gif
Drive sleds from newegg are 7.50 each. I got 16 on ebay for $4.75 each (lowest I've seen, but I cleared them out).
post #1011 of 2256
Which drive trays did you get? Have you tested them to make sure they fit? The Supermicro website lists them as MCP-220-00024-0B for the SC846TQ-R900B chassis. Newegg doesn't list this model on their website.
post #1012 of 2256
I do not have the Newegg drive trays yet, but the ones from ebay fit physically. I have not installed a drive yet though.
edit ...
Woops ... the drive trays I ordered from newegg are incorrect. They seem to be the fixed drive trays, not useful. The ones I got from ebay are MCP-20-00001 so I'm not sure even these will work, but you are right, they are not the ones listed on the SM website for this server. Gotta head off the newegg order to cancel. mad.gif
Edited by AlphaG - 10/31/12 at 1:59pm
post #1013 of 2256
The super micro cards that come with the server do in fact support 3TB drives. I am currently running one fully populated in unraid 5.0beta for a useable 60TB.
post #1014 of 2256
edit ...
The google shows this result when searching your part number. Can you confirm CA-MCP221 is on the tray somewhere?
post #1015 of 2256
if you bought from ebay ( opteron version of 4U supermicro),the motherboard only support pci-express 1.X
m1015 (pci express 2.X) supports 6G sata. I doubtly M1015 would give a boost performance compared with SAT2-MV8 (PCI-X).
I tried IR M1015 , the card did not detect properly, and switched back to SAT2-MV8
post #1016 of 2256
ditto, tested with seagate 3T drive ...
pretty old card but support 3T drive...
post #1017 of 2256
I do not know what that part number refers to, but there is a sticker inside the dummy trays that says MCP-220-00001-01. The plastic trays themselves have another part number imprinted on the bottom.
post #1018 of 2256
I have three controllers (8 drives x 3 controllers = 24 drives). I replaced the motherboard with one that had more x8 PCIe slots. But you could also address more drives off a SAS controller with a SAS expander, but be careful as not all controllers and expanders play nice with each other.
post #1019 of 2256
Well, changing out the controllers AND the motherboard would perhaps let me virtualize, but I am going to go with what I already have, especially with the indications above that the SAT2-MV8's will support 3Tb drives. The more I modify the already great deal of a system, the less of a value it becomes.
Well, I just placed my first order for the drives that will go into this system! A couple of 3Tb Western Digital Red's that are on Amazon for $164 each. Instead of pulling one of my working drives out of my desktop for testing, I'll wait for these drives to get here to make sure everything works.
post #1020 of 2256
If you start replacing motherboards and controllers you might as well just buy a brand new Norco 4224 and build a system from scratch. The best part of this deal was that you got a fully functional server that can support 24 drives. Aside from the recommended modifications to the chassis, all you needed to do was populate it with hard drives and install your OS to be up and running. Replacing major componenrts defeats the entire purpose and nullifies any savings.
