I had been thinking I needed to make my theater room a bit larger. It is a 13 by 16 bonus room. When we built our home the wife and I planned this as the theater room. Over the last 13 years it has gone through a lot of changes. I have had four projectors in the room. I have tried out four different types of screens. The first was a Sony LCD. Next came a Barco CRT I bought used. Then came a Infocus 4805. Then I found a buy on a Mitsubishi 3800. Each new projector was a time to put in a new screen. The sony had a 103 inch 4:3. The Barco used the same screen for awhile. I did experiment with a silvered curved screen for the Barco but it didn't really work out for me. When I got the Infocus I painted a new screen. Most of my screens had been painted directly on the wall with various types of popular one color options from Home Depot or Lowes. I personally don't want to take the time to do the mixing and stuff for some of the popular mixes. Brilliant White or Silvercreen was a fast way for me to get things done on my busy weekends. I went from on wall screens, to parkland plastic screens floating off the wall with no boarders. I did like the floating screen a lot.
Anyway back to the desire for a larger theater room. Now I could not rebuild the room. I did have a pair of Paradigm 9 SE Mk II that had been used all these years. I knew that if I ever changed them it would be to a smaller pair so I could maybe hang the speakers on the wall. So one day I had just had it with the towers. I figured if I am going to go the route of on wall speakers, I may as well try out a acoustically transparent screen.
I went to Joanne Fabrics after finding on this forum about White Ponte fabric. I went shopping and bought the fabric and 1x3s from Home Depot. I pre-cut the wood in the garage and assembled and stapled the frame in the theater room. The stapling went well. No wrinkles and the frame is pretty strong. I used the wrapped felt around the frame idea and it looks pretty good.
I did it all on Sunday over the Memorial Day weekend. I filled up the day with the project. I took my time and did the cutting and assembly with grand children looking on. They were fascinated with the project. Especially when I was ironing the center fold out of the ponte while it laid on the floor.
I ended up with a 100 inch screen. I used the same hanging method I used for the floating screen which was a 93 inch screen. The screen hanging idea was perfect for this new project. Two 2x4s mounted on the wall to use a french hanger idea to susped the screen. The 2x4 was a perfect spacing for the on wall speakers behind the screen.
So what speakers am I using behind the screen? Now is when you all get to laugh at me. I mean if you have not been laughing enough about using Paradigms for the last 13-14 years you will be rolling on the floor with this. I had bought a pair of Minimus 77s for my computer speakers at a pawn shop. I loved them. As old as I am (61) I remember the Minimus speakers being a really great sounding speaker for really cheap. I used them decades ago for my audio needs and I am very familiar with them. Yes there had been better in their day, and is now, but for the price and what can be done with them they are fantastic speakers. I bought another pair when they once again showed up on the shelf at the pawn shop. So now I have enough, and a spare for the front. I put the speakers on the wall behind my new screen and I am really loving the results.
I had found with my Paradigm CC-350 I was having trouble hearing the dialog. I knew I had some hearing loss from my lumber mill days. I would get the TO LOUD complaint from the wife and would turn things down and then I couldn't really make out the dialog. So now I have a Minimus speaker doing dialog service and guess what. I can hear the dialog clearer now than I have EVER heard it in my theater room. I can turn it down to where my wife says it isn't loud enough and I can still hear every word clearly. Who knew. I guess I have something I may need to look into fixing with the Paradigms or my ears just can hear better with the Minimus speakers.
I like the white ponte as a acoustically transparent screen. I have re-adjusted all the levels for my 7.1 system and I am really liking the sound of my new theater. The pans are much nicer and smoother from back to front or front to back. I also like the front panning better. Yes, having a speaker behind the screen does make the front stage more relative to the screen action. I could aways hear the disconnect of mouth moving and speaker below the screen effect. Now that is gone, and with it came smother pans throughout the room. I like it.
As to what are my surround speakers. They are Paradigm in wall speakers. They were chosen to allow surrounds without taking up more room in an already small theater room. They seem to work fine with the minimus 77 front stage. I have not been able to hear any timbre change during the pans around the room. The sound just moves from one place to another without calling out the change in timbre at all. Lucky I guess. It may also help that the Minimus and the paradigm side surround speakers have a silk dome tweeter. I prefer the sound of the silks over metal domes. The speaker levels were actually easier to adjust with this new setup. My seating is 10 feet from the screen. My rear speakers are 6 feet behind me. The side surrounds are set a bit behind the couch on the side. It is a pretty nice layout overall. The front L/R pair are now not as wide as they were but I am ok with it so far. I could bring the L/R speakers from behind the screen if I need to widen the stereo front stage if I needed to.
My sub was originally built into the front right wall during the home framing. The sub plays out of a heating vent built into the wall below the down firing sub. It is a ported 12 inch JBL auto speaker which is tuned to 22 hz. It plays pretty loud and is pretty darn clean. I had built it myself and the framers that built the house were pretty interested in my project while they were working. Later I added a second sub to the back left of the room by making a snack table next to the seating that doubles as a sub enclosure. It is also a ported JBL which is a twin of the front subwoofer. I don't lack bass in the room at all, and the integration with the fronts is working very well.
I don't really see a major difference in screen image. Sharpness is still great. Without a chance for A/B comparison I am happy with the new setup. So if you have been considering it. I suggest you try it. So now I have reached my goal of a bigger room. The towers in the front are now gone as is the center channel. I have an extra 2 feet of space in the front. The grandkids now have more room to lay on the floor and watch a film on movie nights at Nana and Papa's.
