AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-NR818 "official" owner's thread discussion
Onkyo TX-NR818 "official" owner's thread discussion - Page 41
post #1201 of 7316
I said I'd report back on my findings, as requested by several thread subscribers...
Just got my 4311 from EE yesterday; first impressions (vs. the Onkyo818 I just returned):
1) Not quite as nice looking as the Onkyo 818.
The display is very difficult to read, the 818's display was a bit better.
I liked the front face of the 818 better (wider drop-down panel, the larger volume knob
Rear speaker connects are better on the 818; they are side by side as apposed to vertically stacked. I think we can all agree if you are not one for banana plugs, this is a bit more annoying to access , especially if you have large hands (and I do).
2) Not seeing the HDMI handshake issue which the 818 had; well at least not as bad. When I switch channels or sources, i get a brief 1-2 second blank screen (which is totally acceptable to me) but I'm not getting that annoying on screen message stating "no input device connected blah blah" which I got with neary every channel; change on the 818.
3) Airplay is fantastic. This was one of the peripheral reasons I returned the 818 and went with the 4311. The native Spotify app/client was perfect, except for not having a shuffle function. That rendered it useless to me, and Onkyo has no way to easily stream content without making a wired connection. That was enough to say cya for me. I set up an old iphone 3gs to play Spotify via airplay to the 4311, it works well but im getting some jutter occasionally which im not sure of it has to do with my wifi or of it is a denon issue. Wondering if anyone is familiar with this. the stream just stops, and then re-engages 10-30 seconds later. very annoying.
3.1) I am however seeing a very odd issue when using airplay to wirelessly stream spotify from my iphone, in which the tv screen goes on and off (not powered down, just black, i suppose like a screen saver, or some power saving mode which i cant seem to locate the source of, and yes i checked my tv and that is off),
3.2) Poltergeist:: Even worse is this odd, static-like, frayed wise looking glitch that goes on and off every 10-15 minutes. it looks like the (i think hdmi, but maybe it could be something else) connection is just barely being made, and then not being made, and then just barely being made again...like if i were actually holding the hdmi plug at the port and just barely making the connection, pushing and pulling it out exactly at the point that the contact is made). This clears up after 1 second and all is back to normal, but it is very odd and a bit concerning currently. It almost seems like there's a loose wire somewhere, but i'm not sure how that would happen if nothing is moving.
4) Audessy set up was a breeze, and although i think I like it ever so slightly better than the 818's Audessy, They are nearly identical, especially since I only have one sub-woofer and have zero plans of adding a 2nd one anytime in the foreseeable future. i just don't get the whole "i need two subs" thing.
5) General set up was slightly confusing. Onkyo takes you by the and and walks you through a highly intuitive, user friendly set-up process. Denon, by comparison is a scatter brained confusing nightmare. I mean, I mostly figured it out but it was not intuitive and anyone that is not particularly A/V tech savvy, would seriously struggle.
6) Denon's on-screen (tv) interface is ugly, looks dated like from the 80's, and (apologies for repeating the aforementioned) a bit confusing and not very well worded. They should really beef this up. Not particularly confidence inspiring to see graphics which aren't much better than my coleco telstar pong (http://goo.gl/rgUko) from 1977.
7) Onkyo's remote control was better, maybe 15% better. not a deal breaker by any means and I have a Harmony one (which i find annoying to have to scroll through the touch screen to change the inputs btw). The 818's remote was just a better design.
8) I think the 4311 does a better job of selecting the best audio format for the content being played. Im not really sure about this, and it might just be coincidence but on the 818, it would always default to multi-channel which was very annoying, the 4311 seems to just get it right. Again, not a lot of mileage here so this could change in a few days when i have more usage but first impressions seem good.
9) Off topic here but while the 4311 came double boxed, the outer box was a plain unmarked cardboard box, which as far as i am concerned is idiotic on the part of EE to do this. I watch UPS guys toss, throw and bounce unmarked boxes around all day long. they assume there is nothing fragile in there if it isn't marked as such. I am sure this was thrown around roughly because of this. A simple "fragile" sticker could potentially make all the difference here but they didn't do that. Considering how large and heavy this box is, I cant imagine the UPS guy took the time to slowly bend down and gently place this handle-less box down. I found myself wanting to throw it down, but obviously I didn't.
Overall, I'm very happy and if I can clear up or at least understand the root cause of #'s 3, 3.1 and 3.2 I will keep this unit for a very long time. If i can't then I'll probably return it for an exchange and if ti happens again I'll be shopping for something new.
I'd really appreciate any feedback on any of the items I listed here.
Thanks guys,
Jason
post #1202 of 7316
Originally Posted by 6sj7gt View Post
I agree the 4311 is better featured. If you can get it "for the same price" it's a no-brainer.
Problem is, I seriously doubt you can get a 4311 for the same price as an 818. But if you can, by all means do it.
Woke up this morning and saw the 818 at Amazon for $885...lowest I have seen in awhile. So I bought it immediately.
Now looking at the Amazon price it has dropped a few more bucks...
post #1203 of 7316
Thanks guys,
Jason
Thanks for sharing your opinions.
I read over it quickly but I didn't seem to see anything on sound differences?
post #1204 of 7316
who needs airplay? i have an appletv...
post #1205 of 7316
Airplay is cool though.
post #1206 of 7316
I assume that if you use the airplay that you inserted into the Apple ecosystem (macbook, iphone, ipad etc), and an appletv for $ 99 makes perfect sense.
post #1207 of 7316
It's at $882.69 right now.
The price has also dropped on the 3009 (which I've had my eye on) to $1,319.41.
They seem to be targeting Vann's pricing.
post #1208 of 7316
I agree. If you know where to find the 4311 for the same price, then please share.
post #1209 of 7316
it's difficult to say regarding sound differences; even if i played teh same content side by side with two avr's plugged in and going back and forth, i might have a hard time saying which was better or how they were different. Since the Onk got sent back and i plugged in the 4311, tough to say. ill take a stab and say the 4311 sounded a fraction better across the board but i dont think there is a major sound quality difference between the two.
i might notice this more once i get back into a routine of viewing/listening to similar content over the next week or so. if teh center channel dialogue is better, ill know very quickly, since im very sensitive to that.
post #1210 of 7316
can you comment on the difference in the video section?
post #1211 of 7316
negative!
i'm a card carrying apple hater. this was a very difficult decision to cross my self imposed apple picket line and roll with airplay; Onkyo all but forced me to do so. just happened to have my friends old 3gs, so i figured id install spotify on it and see if ti actually works, totally worked, just need to iron out the kinks. no chance im getting apple tv.
post #1212 of 7316
can you be a bit more specific in your question? what exactly would you like to know?
post #1213 of 7316
This is just what I wanted to hear. Maybe a bit better but not too noticeable.
post #1214 of 7316
how they treat the image, upscaling video processor etc.
post #1215 of 7316
negative!
Yea I love the iPhone/iPads but anything other than that I stay away from.
The big thing too is that since those devices are so popular it is easy for friends to come by and share with their devices with airplay.
post #1216 of 7316
Thanks for that very detailed report Jason!
1) I also don't like the 4311's built-in display, but I'm trying hard to not let such things interfere with the important stuff. What the 4311's front face lacks is made up for with the source select knob - a much better idea than Onkyo's tiny buttons and their barely visible labels IMO. One would think Onkyo should realize these things are used in home theaters, and some of them are dark rolleyes.gif
3) Try using a wired connection, if only temporarily. Wireless just involves too many variables, and if a wired connection doesn't stop streaming you found the culprit.
6) For what it's worth Onkyo's on-screen graphics have come a long way in the past couple of years. My TX-SR609's were hideous. Denon ought to catch up. How difficult could that be?
9) It really makes no difference to mark anything as "fragile" no matter what shipper is used. UPS treats all boxes 100% the same, which is to say expect it could be dropped, thrown, or otherwise abused. It's up to the sender to make sure it's appropriately packaged. I'm sure Denon has considered the potential for such treatment and designed its packaging accordingly. Your 4311 most likely came all the way from Japan in Denon's box. EE probably adds its own box as a precaution, as well as to conceal the expensive contents.
post #1217 of 7316
no idea. i only watched some msnbc and breaking bad. they both looked great, and im not sure if this is realistic but i felt like the image quality was slightly more crisp and clear than with the 818. trust is that i dont even knwo if teh avr is touching the image at all, or if it is direct from the sat box. could be many variables leading to that or i also could just be mistaken.
post #1218 of 7316
The online e refurbished 4311's are the same price as the $400 overpriced 818's in store at best buy in Canada. Best buy is not competitive at all with American online pricing. For example the 709 was $999 up until a couple weeks ago.
I would go the online ordering route except most companies won't ship to Canada and the ones that will are no better prices than the Canadian retailers. For example new egg.CA.
post #1219 of 7316
I had the budget to buy the 4311 or the 818. The primary reason I picked the 818 is for the newer/supposedly-better video processing capabilities, the VGA input (great for security system PC) and a few other things.
From what I can tell the primary advantages the 4311 has are Airplay and "sub-eq' for XT32 if you have two subs.
post #1220 of 7316
Wouldn't the TX-NR3010 be a better match to compare to the 4311?
post #1221 of 7316
Why aren't there any professional home theater reviews on the 818? Has anyone found any? (Widescreen review, home theater mag, sound & vision, etc.)
post #1222 of 7316
post #1223 of 7316
I cannot even find the 818 at newegg.ca (nor the 4311ci, for that matter) ?
Amazon.ca has a price surprisingly close to its US counterpart for the 818.
Neither are authorized dealers though... If I decide to get an Onkyo, I'd probably ask a local authorized dealer to get closer to Amazon's price.
post #1224 of 7316
All of the following is IMO
with one sub 818 > 4311
with 2 sub 4311 > 818 depending on your skills n tools
SuqEQHT can be accomplished in other ways.
use those ways with 2 subs... 818 > 4311 (cheaper than price diff)
With 3 sub (that's what freq response ninjas start with) 4311 offers nothing above 818 You already need better tools and smarts than SubEQ HT.
just sayin
EDIT: but if you want 11 channels, 4311 rules the land
Edited by dstew100 - 7/19/12 at 10:02pm
post #1225 of 7316
I had a 4311,didn't like the video processing at all.Returned it got an 818.
post #1226 of 7316
post #1227 of 7316
Originally Posted by joerod View Post
lol...how they drop it $20 in one day...quite annoying to me having bought it yesterday....
I think I will wait to see if within the next 30 days the price is dropped closer to $100 and them complain to them....
post #1228 of 7316
What else made you switch?
post #1229 of 7316
So I got best buy Canada to match amazon.CA's price and beat it by 10% end up saving around $350.
I don't have time to set it up. I unboxed it and realized it won't fit on the middle shelf. Couple inches too long with binding posts. So I put it on the top shelf, but now the center speaker has to go down to the middle shelf. Not ideal but within 6 months I will have a dedicated room so I will be fine for now.
Quick question: I run an Xbox, a htpc that also does gaming, a telus optik set top box. For gaming, video lag needs to be minimal.
Do I run everything into the receiver and then single HDMI to the TV or do I run everything to the TV and then do HDMI ARC back to the TV ? I do not intent do use any of the receivers video processing.
post #1230 of 7316
Start off w/ everything connected to the AVR and a single cable run to the TV. Make sure you choose the right VP settings per input (Game for the 360, and HTPC, probably Custom for the STB).
Don't write off the VP capabilities, while you probably don't want then for the HTPC and 360 they should exhibit a marked improvement to what the STB can do. So make sure to try setting the STB to native output and let the AVR do scaling, NR, etc. instead.
