Try to reset the microprocessor and run Audyssey again. Report back please.
For Onkyos the usual way is this:
If you go into Speaker Setup menu and select Speaker Configuration, does it not allow you there to tell it if you have one or two subs? That is how it has always worked on the 3 Onkyos I have had.
The only issue I ran into was my entertainment center shelf is not deep enough to hold the unit with banana plugs installed. The receiver currently is sitting on top of a small ladder! I will have to cut out the back of the unit to gain the room.
The wife can just get mad, she should have consulted me before buying the stupidly designed thing...
If you like it now, you will love it once you have run Audyssey!
If you're new to Audyssey, check out the Audyssey '101' Setup Guide and FAQ, linked in my sig, to help you get off to a flying start.
