how do u know that it doesnt transfer the signal untouched? do u have any proof that u say it simply doesnt?
Ok, in your case you can claim it is normalization (but really it isn't - both curves as is are weighted and normalized to the same base perceived loudness already, the level sets the gain of the uncorrected one to the reference perceived loudness, audyssey corrects everything to the same loudness), as it is within 3dB in your case, some precision tolerance can be claimed also. In my case - you can't even claim any of that, as if you move the basic curve to the highest point of audyssey graph above roll-off frequency - it will obviously already off in level (audyssey will be quieter as it is quieter in every freq. point that produces reasonable sound pressure), but still the boost will be higher than that... Isn't it normalization bug? And if you start to talk about perceived loudness of frequencies bellow the lowest frequency - then it would be total nonsense as there is nothing to perceive there except the distortion at any reasonable level.
