AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-NR818 "official" owner's thread discussion
Onkyo TX-NR818 "official" owner's thread discussion - Page 168
post #5011 of 7043
Originally Posted by IgorZep View Post
The 'pumping' could just mean (and I think it is) that when there is a note on that frequency it quickly sucks all the power from the power unit capacitors (while still not producing any reasonable sound pressure in the end), and there is much less power left for producing other sounds just few moments after this note is started. Something like that in simple words.
I need to test it more but I've been so happy with it disabled that I haven't been inclined to follow through.
As an example, if someone on the track started a sentence with the word 'but', it would sound like - bUT. The 'bah' part would start at out one volume level, then the 'UT' would suddenly jump up to a very obvious degree. If the sound track in general was busy, then of course it would be less noticeable, but as soon as a quiet portion is interupted with something, it would be very obvious to the ear. A tiny lag, but still impossible to ignore.
post #5012 of 7043
Originally Posted by RPGMasta View Post
I apologize if i missed this in my searching, but i have a new problem that just started two to three days ago. My Net function no longer works. I have internet connection, but even if i was having network issues, i would expect the Net to still display the menu as normal. It no longer shows the menu, just a black TV (though it does display NET at the bottom right) and no menu on the receiver display. I am able to connect to the receiver via browser, through two different ports on my switch, so i'm 99.9% certain it's not the ethernet cable.
I recently connected a WD Live TV, but i would still expect Onkyo's Net ability to work. I disconnected the HDMI for the WD Live TV and still nothing from the 818. Any suggestions?
Can you access the Network configuration details through the Home-> Hardware Setup -> Network, and check the IP address configured on the receiver. Make sure the Gateway and DNS Server details matches your internet router's configuration. If you have access to your router's administration interface, check to make sure that your receiver has an entry in the clients list, and see if you can revoke the DHCP address lease for your receiver, forcing it to renew its IP address lease from the router. You may alternatively try to unplug your receiver from the router, reboot the router, and once it's back online, connect your receiver to the router. Try these steps and post your findings.
post #5013 of 7043
I've played with audyssey a lot and on a lot of different receivers. However on the 818 it does seem to over boost the high frequencies more than any other receiver I've tried it with. I currently do not have a good way to take measurements. I am working on getting someone with an omnimic over so we can test it.
post #5014 of 7043
Thanks raaj
I did find the IP, that's how i was able to access the Receiver's settings through my PC browser.
I might not be gifted enough to revoke the DHCP lease, but I did remove the Onkyo's IP (matched MAC address just to be sure) from the DHCP client list through my router's admin interface. it has not shown back up on the list before or after router reboot.
i have verified it is not the cable, as the BluRay player still reaches the internet after swapping.
post #5015 of 7043
So the signal gets actually louder after the first syllable?
post #5016 of 7043
Yes. As if its just a fraction too late in raising the volume to meet whatever level it is trying to equalize the track to.
post #5017 of 7043
Weird. Are you sure it's not the other way around, first syllable is loud, following syllables are softer?
post #5018 of 7043
Originally Posted by MadMyers View Post
At least that's my guess... others please chime in!
Yep. Large == Full Band == no bass-management == no crossovers.
Small == with bass-management == some crossover set (can be any, usually from 40Hz up to 150Hz) == bass below crossover frequency is redirected from satellite channels to the sub.
If there is no sub in the setup then there is no bass-management, no crossovers and everything is Full Band or 'Large'.
post #5019 of 7043
Onkyo does a very good job with discrete IR codes! They really deserve kudos for this. Pretty much everything has a discrete IR code.
Here are a couple I've programmed into my Harmony (using concordance and concordia):
1) Enable Audyssey Music
2) Enable Audyssey Move
Unless I was missing something, there was no quick way to change those. Now, either the data Onkyo provided has these reversed or I accidentally reversed them --- need to try again tonight.
3) Disable Audyssey
I don't expect to use it, but it was easy to program.
4) HDMI Out = Main
5) HDMI Out = Sub
6) HDMI Out = Both
I'm currently running in Both mode, but being able to quickly switch modes may offer some flexibility in the future. Maybe not --- I haven't noticed any important loss of functionality using Both.
If you want the codes, just send Onkyo an email. I got a response quickly.
post #5020 of 7043
Originally Posted by Wryker View Post
I love my 818. I listen to my mp3 mixes stored on my PC via the network play and no issues (no audio drops). I'm not sure what you mean by blu-ray playback since I watch plenty of BDs and my .ts files on my Popcorn Hour without any issues (the 24fps issue is resolved w/the firmware recently available).
The ONLY issue I have with mine is the I can't watch/use my Logitech Revu with it. It wont' send the video through the MAIN HDMI out - only the SUB.
I love my 818. I stream mo3's as well. love the sound and picture. It would definitely still be on my list as well.
I wanted to also say, I am using the Logitech review and I'm not really having any issues. Im wondering if it is a setting on the review itself that is causing you grief.
post #5021 of 7043
I've tried numerous settings and it won't pass-through comcast cable. What settings are you using on yours and I'll give it a try!
post #5022 of 7043
when
I get home I'll look the settings up and let you know. I do know I'm only using the Main out. And Im not positive but I'm thinking you won't get 5.1 DD. that's really the only gripe I have with the Revue other than having to unplug it once in a while to get you tube running smoothly.
post #5023 of 7043
During setup if you declare that there is no subwoofer in the system then by default fron speakers are set to large. That means that full spectrum of frequencies goes to them. If for some reason you want to cut off some fraction of the low frequencies then you should declare that there is a subwoofer, even if it is not, and then you have the option to set the cut off frequency for front speakers according to your tastes. That is for manual configuration, otherwise in auto setup you just let audyssey to measure the capabilities of your speakers and decide the level of the cut off. Even in this case setup GUI insists in case the speakers you use (front, surrounds, all or some of them) are THX ceritfied then to manually out the cut off frequency at 80Hz.
The rest you are mentioning about boosting some frequencies has to do with room acoustics and mostly are depedent on the specific and are highly affected by the way each one measures (i.e. placement of the mic...).
Regarding small or large speakers is the same for (almost) all brands, I have read (almost) all brands of user's manual during my market search, all say the same thing...it is a surpise to see this misunderstanding through forums.
post #5024 of 7043
Just a thought but if you are experience results that are far off from what you are used to maybe you got a bad setup microphone? Might be worth a shot to ask Onkyo for a replacement.
post #5025 of 7043
How does everyone feel about the Dolby Volume feature? I really like it but I notice, you can't have dynamic EQ on at the same time. Any advise on the best way to go?
post #5026 of 7043
I will be doing just that. I really hope its that simple.
post #5027 of 7043
Originally Posted by cpetku View Post
I really liked the online reviews of the 818 when it came out and was looking to pull the trigger on a purchase today as I re-arranged audio equipment and started planning on m oving old equipment into the basement exercise room. However all of the discussions on Blueray Playback and network issues (gaps in audio) for the past six months have me concerned that this unit will never live up the the potential with which it was introduced. The question I have to ask is if you owners had it to do over again in the next couple of weeks, would the 818 still be on the list or would it be something else? My primary use cases include HDMI switching, DLNA streaming from a NAS and Internet connectivity such as Pandora.
I'm very happy with mine however, I don't use it for any of the things that you will. I play all my music through ATV2 or via radio. I was a little concerned musically coming from a $1600 ( Canadian ) Arcam AVR200 purchased in 2002 to this $899 unit however, there is no questioning the tremendous value that this unit provides. No regrets for me.
post #5028 of 7043
I am also having some unexpected results from my calibration using the XT32 implementation on the 818, and I never had this sonic signature (fatiguing high freq response, missing midbass, etc.) with the latest Denon and Marantz receivers, using the same mic locations. The only changes in the system are the Onkyo receiver and a new sub, and I don't think the sub would lead to a brighter sound overall after calibration. Hope a replacement mic would solve the issue. I will request a replacement from Onkyo.
post #5029 of 7043
Have you followed the Audyssey 101, linked in my signature?  If you follow the advice there, to the letter, you should get a good Audyssey calibration.
post #5030 of 7043
Yes sir, I have read way more of that thread then I probably should. This is defiantly not my first Audyssey rodeo. I have a feeling it is the Mic but I don't have anyway of knowing for sure. All I can do is compare the results with my Denon 2809 that has MultEQ XT. I don't know why XT32 would boost my high frequencies more then XT. But I am positive it does. I will go ahead and request another mic and see if that has any effect.
post #5031 of 7043
To whom are you replying here? The last one who told about boosting and had posted measurements was me. Then you missed the point that measurements I presented as a proof was not acoustical, but electrical from amp. pre-outs, and the boost was bellow F3 (the detected by Audyssey -3dB frequency).
post #5032 of 7043
a)9. Why are my high frequencies 'bright' or 'harsh' since running Audyssey?
This can happen if the main speakers are not ‘toed-in’ properly, or angled towards the MLP. In these circumstances, if the Audyssey mic is off-axis from the tweeters, Audyssey can boost the high frequencies in order to achieve the desired response. There have been anecdotal reports/speculation that XT32 is especially ‘sensitive’ in this regard due to its super fine resolution for correction. So, if your HF is too bright or even harsh after running Audyssey, and your speakers are not angled towards the MLP, try repositioning them and running Audyssey again.
I have a feeling this could be my issue. If XT32 is more sensitive to this, then that would explain the difference. Whats funny is anytime I set someone else's theater up I always toe their speakers in. But in my current theater I can't so I haven't. I will test this tonight though. I hope this is the issue. Because I will only have to deal with it for a few more months. Once my new theater is finished this will no longer be an issue. Thanks KBarnes701. Even when you think you know something it's always good to try to learn it again. tongue.gif
post #5033 of 7043
It seems there is definitely a freq-out happening either on part of the Onkyo, or XT32 in how it evaluates my system. With regard to "toe-in", my speakers have ribbon tweeters, and have not had issues with prior calibration using MultiEQ XT on the Denon/Marantz receivers I had with the exact same placement of the speakers and the MLP. My tweeters have a -10dB drop at 30 degree angle off-axis, so they have a decent amount of horizontal dispersion for my setup, to not pose off-axis issues. So, it's either the Onkyo or the XT32 that is having a fit in my setup. I should have used the mic from the Marantz SR5007 I had till the past weekend to try sample calibration to see if the mic is making a difference. *smacks head*
post #5034 of 7043
Another mic would be my next suggestion for sure. Have a read of this FAQ answer for more info on defective mics:
post #5035 of 7043
Hope that is it. I just linked you to that FAQ answer, so just ignore the link :)
post #5036 of 7043
Don't beat yourself up - we're all geniuses with 20-20 hindsight :)
post #5037 of 7043
What I should say about 818 and over-boosting high frequencies, yes, it does it for me too. And toeing speakers doesn't really help, the same as replacing the mic. What helps is adjusting Low/High tone controls a few decibels. I guess the not-too linear volume control of 818 is responsible for that (I can see it when measuring pure audio response, once I move level down high frequencies are boosted few dB). As Audyssey measures with levels set to zero, when they are set to something like -7dB, there is some high frequency boost as the effect.
Also what is interesting about this trick when you toe in speakers - you are listening with speakers toed in. But when you measure with speakers that are not toed in, then you are also listening this way at the exactly same position, and Audyssey tries (or should try) to correct everything to the same acoustic level on the same positions... Why it happens that the results are different acoustically - is a pure magic. The only reasonable explanation I can think of is less HF reflections vs the direct sound that sounds less harsh...
post #5038 of 7043
Nothing in my room has moved other than the switch between receivers. One having XT and the 818 XT32. My speakers are hung on the wall so there is no way they moved. But they are also not toe-ed in at all. So there could be some merit to this theory. I will try to test this though.
post #5039 of 7043
Igor, and Stitch1:
You guys have highlighted the problem I was thinking I alone was suffering from. Please continue your feedback on various things you try, in this thread and the general Audyssey thread. I will do the same.
post #5040 of 7043
Wick wick wick wick. I'm running audyssey as I type this. Fingers crossed, I really hope this works.
