Featured Stories
Topics Discussed
- brandAudyssey
- brandONKYO
- itemOnkyo TX NR818
- categoryReceivers Amplifiers
Related Forum Threads
- good set up?? Last post on 1/10/13 at 10:25am in Speakers
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- ext amp question Last post on 1/2/13 at 8:59am in Receivers, Amps, and Processors
- Looking at buying a Receiver Last post on 12/31/12 at 6:04am in Receivers, Amps, and Processors
- probem with oppo hdmi handsake with onkyo receiver Last post on 3/2/13 at 2:22pm in Blu-ray Players
Related Articles
Audyssey FAQ and New User '101' Help & Setup Guide
Edited on 1/20/13
- Audyssey FAQ and Beginners '101' Setup Guide
Edited on 8/22/12Related Reviews
Onkyo TX-NR818 "official" owner's thread discussion - Page 187
Gear mentioned in this thread:
Igor,
I stated my understanding based off information I have read from multiple respected sources, asked you to cite other relevant information which supports your position, you cited none and became rude. Again you make inaccurate claims about me personally and do nothing to advance a technical discussion. I'm not going to sit here and repeat basic facts about filters; you have been advised.
If you have a magical filter which has no negative impact on the faithful reproduction of the original source, well you'd be a a very rich man. But at least you believe you have such a filter and since it is increasing your enjoyment of your system, that's great. At least you have magical filters and video firmware which fixes audyssey bugs, most of us aren't so fortunate.
I newer told that the video fix fixed my problems with Audyssey. I only told that there was a sonic improvement after the update. I don't know the reasons (I don't have the sources, do you? I don't know if previous update was flashed with no hidden errors). But there was a difference, and not only audible, but also metrical one - the crossover frequencies were detected consistently higher. There is not so much difference in the electrical response, but I had no time to go deeper into measurements.
I do think there would be a benefit using the 818 active crossover feature with a speaker which does not have a passive crossover network. The full implications aren't clear to me about the effects of using it on a speaker with a passive network, I hope others will chime in with relevant information, but I have stated my concerns and a couple of sources supporting those concerns have been provided.
Analog filters aren't "imprecise" either.
And yes, speaker drivers themselves have some phase, frequency response and sensitivity irregularities that are usually corrected/matched with passive crossovers inside the speakers. The ideal digital crossovers will miss those 'corrections' and will be only responsible for matching phase/level/delay in the crossover region.
There is no such thing as "the" digital crossover. There are digital filters that behave just like their analog counterparts. This is probably what your graph shows. So nothing is gained when replacing a existing passive crossover with a digital one. Nevertheless there are digital filters that can do a lot more. FIR filters can change phase without affecting magnitude and vice versa.
But as I've said before, there are more things to consider when designing a crossover from scratch. It's not just the on-axis response that is important but also the off-axis response. No trivial topic.
You can't correct the on-axis response of a speaker without altering its power response. Besides that, one can't measure the free field response in a living room. There are too many reflection too early in time that contaminate the results.
Edited by markus767 - 3/9/13 at 2:41am
- InfernoST
- Trader Feedback: 0
- offline
- 148 Posts. Joined 12/2012
- Select All Posts By This User
I needs some help understanding 7.1 & 9.1 operation, this is what I'm coming away with after reading the manual.
5.1 Operation
Front L & R, Center & Surround L & R are driven via the receiver amplifiers.
7.1 Operation
Front L & R, Center & Surround L & R are driven via the receiver amplifiers with the option of adding only 1 more of the following that will also be driven via the receiver (Front High or Front Wide or Rear Surround).
9.1 Operation
Front L & R, Center & Surround L & R are driven via the receiver amplifiers with the option of adding only 2 of the following with only one being driven via the receiver and the other requiring an external amp for the other (Front High or Front Wide or Rear Surround). The receiver is not capable of outputting all 3 at any one time.
9.1 Additional channel Configuration
A)SB Channels Driven by the receiver FH Channels Driven by an external Amp
B)SB Channels Driven by the receiver FW Channels Driven by an external Amp
C)FH Channels Driven by the receiver FW Channels Driven by an external Amp
Please let me know if I have this right, Thanks.
Can someone please confirm the above for me also is this only for 5.1/7.1/9.1 encoded content? I'm a bit more confused now because when I'm listening to a CD or FM radio etc and the listening mode is set to anything that support 9.1/9.2 playback all of my speakers are active. Thanks Guys.
The graph I posted shows that there is nothing lost in the frequency response of the ordinary speaker with analog crossovers when we add digital crossovers with overlap and do not remove analog ones from the speaker. And there is nothing more needed to match the filters except setting proper frequency value and enabling overlap. This is what was objected when I made that claim initially.
You will be using these speakers in the same room in the same place after all, with all those reflections etc.Why makers of the speakers don't do it and use free-field measurements is because they cannot optimize the speaker for every room on the planet and there are no standard to the rooms and the placement of speakers in them.
- InfernoST
- offline
They are. They are made from imprecise components, any analog component is imprecise, the capacitance of every other capacitor is different to the next one in the factory line... This is the main reason that building high-slope analog filters is so complicated - it is too hard to match every detail so the LPF+HPF would work together with no problems. Digital solves this problem as every virtual equivalent of the analog filter is 'ideal' one with precise and 100% repeatable characteristics.
Are you expected a change in the frequency response from active bi-amping. Please... Frequency response improvements is not what is gained by active crossovers. It meant to solve different things. The out of band signal was filtered out from the signal before DACs, so it had no chance to affect in-band signal anywhere in the analog chain - this is what gained.
Sure, but we are talking about crossovers and bi-amping. My only word here is that if you do bi-amping then active filters are an improvement, both in case if you completely replace passive filters in speakers by digital ones in receiver (this is not easy, as you have said - you have to do the matching based on measurements or you end up in doing more harm than good), and also in case if you leave passive crossovers in the speakers (then the setup is very easy, but you still have excess component - the passive filter - in the chain of signal). The question what is better to use spare amps for more channels or to bi-amp some existing ones - is another topic and it is more in the personal preference territory.
Most of the talk was about the case when we leave passive crossover in speakers, then you don't design the crossover from scratch, you only help it to better filter out-of-band signal and do it even before the amps, so the out of band signal just newer reaches the corresponding amp and passive crossovers in speakers.
You don't have to
Does any of this have to do with the 818????????? Enough already!!!!!!!
I won't respond to the many things you got backwards about crossover design, filters, signal handling and room correction.
If you want to get a glimpse of what it takes to develop a speaker crossover then this is a good start: http://www.linkwitzlab.com/crossovers.htm
About room corection: http://www.dirac.se/media/12044/on_room_correction.pdf
Let's concentrate on the 818 which is what this thread is about.
Do we know what filter characteristics the 818 offers?
Do you have a speaker with a crossover that matches those filter characteristics?
- kbarnes701
- offline
- 10,413 Posts. Joined 1/2008
You don't have to
Yes it does IMO. FWIW, this is my take on it: The 818 has an apparently 'new' way to biamp speakers which is unique AFAIK in the AVR world, or certainly so at the 818's price point. Some people believe that this 'new' method of biamping is flawed because it requires (in one configuration) that the passive crossovers in the speakers are still used, others say that that this is not an issue because of the clever way the 818 works. There is now a highly technical discussion going on between Dstew, Markus and Igor as to the rights and wrongs of this biamping methodology. In general, such a deep discussion of biamping, filters, crossovers etc would be OT in an AVR thread, but in this case, because of the unique implementation of the 818 biamping method, the topic is, IMO, entirely relevant to the 818.
I don't pretend to be able to follow all of the technical discussions in the last posts, but I am trying to because, once a resolution of the different POVs is obtained, or whenever I manage to form a viable opinion of my own (if at all), it will contribute to my understanding that the 818 is a truly remarkable pice of kit. Not only is it capable of being used as a pre-pro, not only does it have Audyssey XT32 (definitely unique at this price point), not only is it a very full-featured unit in its own right, but now it also seems to have a unique capability to 'biamp' conventional speakers (so long as they are equipped with 4 terminals). If the unit was Audyssey-Pro enabled, it would definitely be a candidate for me, if my Onkyo 5509 prepro ever needed replacing.
Personally, I am sceptical about the ability of the unit to 'biamp' (at least in the generally understood meaning of the term) while it uses passive crossovers in the speakers, but the discussion is very useful and hopefully some kind of conclusion will eventually emerge, if the guys can stay focused.
Just my 2 percent of a dollar.
- InfernoST
- offline
I beg to differ, this discussion started out about the Bi-amping capabilities of the 818 and has turned into yet another bickering contest of Bi-Amping and the feasibility of such. These long posts are making it difficult for other members to get questions they have regarding the 818 answered because they wind up a few pages back in quick order.
- kbarnes701
- offline
It's totally fine for you to disagree with me. I've had no difficulty reading the thread personally. It's easy to skip the posts you're not interested in. Which questions haven't been answered - if you highlight them in a post of your own, quoting them, it will bring them right to the latest post in the thread?
Some of us are finding the biamping posts interesting, as I have said. If you aren’t, just skip them. If you feel really strongly that they are OT, report the posts and if the Mods agree with you they will delete them. I doubt if that will happen in this case though.
EDIT: I just skipped back a few pages and found only one post that hadn't been answered, which was posted only 20 hours ago anyway. I have made an attempt at a reply which will bring it up to date (I didn’t reply before simply because my honest answer to the poster's question is "IDK". I suspect you are referring to your own unanswered post but that was made originally 6 days ago - and was unanswered long before the biamping discussion started. Maybe nobody knows the answer? But it doesn’t seem correct for you to assert that "These long posts are making it difficult for other members to get questions they have regarding the 818 answered".
Edited by kbarnes701 - 3/9/13 at 5:51am
- kbarnes701
- offline
I am having an issue that i hope someone can help me resolve
Here is my equipment:
Optoma HD20 connected with HDMI to the main out of the TX-NR818
Oppo BDP-93 hdmi 1 to TX-NR818
Toshiba HD-A1 hdmi to TX-NR818
Xbox360 hdmi to TX-NR818
The issue is that if i am trying to use the Oppo to play audio CD the TX-NR818 returns a HDMI no signa with the projector offl . I have to either disconnect the optoma from main out or switch the onkyo hdmi output to main sub and then the hdmi signal lock in and i can listen to the cd
but if during audio cd playback i switch the output back to main out or reconnect the hdmi cable to main out then the hdmi signal get lost again
Anyone has any suggestions ? Am i missing something??
I am not sure but I don't think you are missing anything. HDMI is an 'end-to-end' technology - if you break one end of the chain it fails. That's why disconnecting the PJ or switching it manually restores the CD sound - it has redone the handshake which you disrupted by not having the PJ on. Others might have a suggested workaround, or tell me I am wrong, but that's my understanding.
- kbarnes701
- offline
What I do agree with you on Igor is that it is great to see Onkyo at least attempting to push forward with something new. And especially in a unit that costs less than $1,000 (typically). And remember it also has XT32. The 818 is a remarkable AVR for the money. I will do more research on this Onkyo version of biamping and perhaps I have been hasty in condemning it outright. What you say above makes more sense to me than what Onkyo had to say in their paper! I can agree with you about the sentence I have bolded above for sure.
KBarnes, would you agree that by bi-amping and using the active crossover included with 818, at the very least you would increase the amplifiers headroom? Even if you do have the passive cross-overs in the speaker box, the amplifiers will not be sending out a full range signal to all terminals. Just a thought.
TBH I am not sure. I have still not gotten my head around the idea of using active crossovers in the preamp and passive crossovers in the speakers at the same time. Amplifier headroom would be increased in conventional active biamping using a separate amp for the LF and another separate amp for the HF (as in active speakers) - but when the amps share a power supply I can't quite see how the headroom is increased.
Igor,
Unfortunately no. OK, not everything. We know that they are very high-slope filters (I haven't reverse engineered exact numbers). You can choose the frequency - with 1/3 octave steps (a weak point IMHO, could be at least twice more precise, another weak point is that 250Hz is the minimal crossover frequency). Then you can apply overlap of 2/3 octave for use with ordinary speakers without removing crossovers. You can choose not to and remove them, or connect to your DIY crossoverless speakers. Then you are on the 'designing your own crossover' advanced territory. And there are more options to configure like trim level, phase (0 vs 180, useless option as it is equivalent to changing phase by reconnecting wires) and delay for every speaker driver (this is really useful one for matching HPF/LPF together with corresponding speaker drivers, there is no analog for passive filters as the delay problematic to achieve in analog, so phase-matching is used there traditionally, they are different tools in some sense, but in other sense phase and delay is the same thing and you can achieve same goals of matching driver's response in the crossover region with both).
It is not purpose of one crossover to be exactly like the other, it's purpose is to match speaker drivers response in the crossover region. In 'traditional' passive crossover speaker design world they also do other things like driver's level matching (dispersing the power to heat instead of sound pressure) and correcting the frequency response of speakers to some extent. For both we have other and better tools in 818.
Edited by IgorZep - 3/9/13 at 6:23am
But sorry to take attention away. Do not hesitate to say loudly HELP and repeat your question
I started a thread about the 'Onkyo Digital crossover network' in hopes that some of the more adventurous folks with the xx10 AVR's had tried it but it quickly fell off the first page with no replies. I also Googled it to see if there was anybody with first hand knowledge (in the whole world) and their impressions--nothing.
As keith says, if you're not interested just skip over it as I do with the posts about hacking into the inner workings of the 818.
Edit: BTW, here are the Onkyo speakers designed specifically for the crossover network;
http://www.intl.onkyo.com/whats_new/2012_0902.html
http://www.intl.onkyo.com/products/speakers/speaker_packages/d-509/index.html
Edited by Patrick Murphy - 3/9/13 at 6:42am
It's a toy to keep knob twiddlers happy. The lack of documentation is completely unacceptable.
If people want to get into digital crossovers, start here: http://www.minidsp.com
For the b) case - this is as usual with any active bi-amping. You have the speaker box with drivers and measurement gear, and do the work matching drivers. Do you think there is no enough adjustments in 818 to accomplish this?
- bootman_head_fi
- Typing away useless posts on the internet.
- offline
- 774 Posts. Joined 11/2002
Isn't this what most modern AVRs are?
It is what keep companies like Onkyo and Denon in business.
There WILL be a new knob to turn every 6 months.
While I agree there should be at least some documentation.
(maybe this was some sort of prototype feature for a future model that somehow made it through in firmware?)
All digital filters have a negative impact to either phase, distortion or both. That fact is not arguable and you doing so shows me your lack of understanding on this topic. Crossovers consist of filters, you attempting to separate them from other filters is not correct. Use of filters in my system improves the overall sound despite their negatives, you claiming I advocate no filters is laughable and rude to be putting words into my mouth. You not caring about the characteristics of the 818's digital crossover shows that you are not taking a good approach to what you are trying to accomplish. Even your comments concerning analog versus digital are a bit alarming to me. Your goal is to reduce IMD, yet "Intermodulation is caused by non-linear behaviour of the signal processing being used." - wikepedia; so to reduce IMD you add more signal processing? My multiple college degrees also consist of a great deal of calculus, differential equations, and physics, but I don't need them to see the flaw in your approach to reaching your goal.
Your word is not going to be good enough to convince me given your lack of understanding on the principles involved, not to mention your rude approach. If you would like to advance the discussion, bring a technical document which supports your position into the discussion. You claim the reason you don't do so is because you are educated in math and physics? Have you ever read a white paper? Again not a good approach. Is the real reason you do not bring a document into the conversation which supports your position because no such document exists? Out of curiosity, do you work in a technical field and if so what do you do? As I've said before we are simply talking in circles as you've done nothing to show my concerns are not applicable in this configuration.
For others, your goal should be to get your system performance as close to your desired frequency response as possible without EQ, then use minimal EQ to further improve the sound if needed (and it is the vast majority of time). That is why acoustical treatments and speaker quality are the two most influential factors to sound quality. My room is not treated yet due to WAF and no dedicated room and I have to make the EQ compromise. I do employ Audyssey XT32 and a minidsp to improve my system despite what Igor claims my position to be.
I do think the conversation is on topic, but since we are talking in circles at this point without Igor bringing in any evidence to support his claims, it's got to be getting old. I know it is for me. I suspect my prayers for his next post will go unanswered.
+1 to each of markus's valid points. His understanding does exceed mine, yet when I do read on the topic it's amazing, all of markus's points are supported by the material. It is the kind of experience which causes me to take note of a forum members contributions.
Edited by dstew100 - 3/9/13 at 10:11am
- Newbie01
- offline
- 824 Posts. Joined 7/2001
Was hoping to get a top 5 things I wish I knew when I first bought the 818 list...
I am trying to wade through all this info and find the gems but it is going very slow.
Example: Video conversion..should I set it to 1080p or 1080p / 24. I have a panasonic VT...so it handles 24 very nicely..but I dont really know.
Anyway...if you guys came give me the "Top 5 things I wish I knew how to do when I got my 818" I think that would be extremely helpful to everyone.
- babgvant
- online
- 1,970 Posts. Joined 2/2005
Set it to 1080p.
I'm not sure what the 1080p/24 setting actually does (besides the obvious conversion of whatever comes in to 24p). Ideally it would IVTC, but it could just be decimation. Better to let the source device handle it, if it can.
Your inability to reason and inability to read what others are telling is already known to me. Don't be surprised I am rude.
How much to each invalid one?
You want some links... you can read here about digital filters and their linearity, and here about audibility of phase shift done by different crossover filters. You can find more resources if you google it
You may not care for digital and that's fine, but your assertions are biased and incorrect, IMO.
Igor
I bought my 818 about 2 1/2 months ago and initialy it was working great. The day before the superbowl I turned the receiver on to play around with the settings and no sound came out of the speakers other than a clicking noise as i turned the volume up or down (this happened the day before I was to host a superbowl party, thank god for my old 605). I ended up taking it in for service and after 2 weeks I picked it up as they had replaced an amp, hdmi board and some chip ( or some other part, cant recall). Got home, turned it on and everything was sounding and looking great until I hit the NET button and noticed that I was missing a lot of apps (pandora, netflix, rahpsody just to name a few). I called it in to onkyo and spoke with 2 techs and they told me that they had never herd of this problem so they told me that onkyo headquarters would call me soon with a solution and for me not to worry. That was 2 days ago and this is driving me NUTS!! Ive searche on this forums and other forums and cannot find anyone with the same missing apps issue. So, before I call them back and flip my ****, I was wondering if anyone has had this problem or herd of anything like this. Ive tryed everything from resetting the unit to flashing the latest firmware with no luck. Am I missing something like a hidden sub menue or something really stupid that I am not doing? Any help would be greatly appreciated.
What apps are missing, and what are there?
If you see eOnkyo and Radiko, your receiver thinks it's a Japanese model. If you see Simfy, it thinks it's European. The data used to determine this is on the HDMI board in the flash for the ARM processor - at least thats where it reads the data from. I'm quite curious as to what it shows: which apps do you see?
- Onkyo TX-NR818 "official" owner's thread discussion
Recent Discussions
- › Pioneer KURO Experience 2008 Download just now
- › What are your most recent Hi-Res purchases? 30 seconds ago
- › The Official HSU VTF-15H Thread 47 seconds ago
- › Harmony Ultimate, Smart Control and Hub 58 seconds ago
- › Official Vizio M-Series Razor Mxx1i thread 1 minute ago
- › For all D-Box enthusiasts ! 1 minute ago
- › Hot Off The Press: The Latest TV News and Information 2 minutes ago
- › Official 2013 Sony R550A series TVs (KDL-xxR550A) --- 50", 60", and... 3 minutes ago
- › Fetch's Theater Build - come inside and take a peek! 3 minutes ago
- › Mint Linux & Asus N76VZ 3 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
