AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-NR818 "official" owner's thread discussion
Onkyo TX-NR818 "official" owner's thread discussion - Page 218
post #6511 of 9486
Originally Posted by RomanBlade86 View Post
Didn't Onkyo fix the lack of gap less music through a firmware update? One reviewer on Amazon said you're supposed to directly request the firmware update from Onkyo to fix this issue:
http://www.amazon.com/Onkyo-TX-NR818-7-2-Channel-Network-Receiver/product-reviews/B007JOO4XE/ref=cm_cr_pr_hist_1?ie=UTF8&filterBy=addOneStar&showViewpoints=0
Originally Posted by NODES View Post
This is news to me, anyone else know anything about the gapless fix?
I looked through that page and didn't see anything about a gapless fix. What is the name of the reviewer?
post #6512 of 9486
I don't know if this had to do with the gapless fix, but I was referring to the 1-star review titled 24 frame per second bug, ruins the experience.
post #6513 of 9486
I've been having a weird issue with my TX-NR818. It seems when I first start it up and use it with my Bell 9242 satellite receiver, after some time there seems to be a serious lag between the 9242 receiver and the amplifier. Whenever I push a button on the satellite remote, say to bring up the guide it takes a good 2 seconds or more sometimes to bring up the guide. Or if I'm trying to fast forward through commercials it takes 2 seconds or more to register the button I've pushed on the remote. This only happens when the amplifier is on and I'm using the satellite receiver through it via hdmi. If the amplifier is turned off and I'm using the hdmi pass through so I can watch tv without the amplifier turned on there is never any lag.
The only fix for this lag problem is to turn the Onkyo amplifier off and then on again and voila no more button lag? I did check for firmware updates and I'm running the latest version on the amplifier. What could be causing this and how can I fix it? I've tried contacting Onkyo and explaining this problem to them but they don't have an answer for me?
post #6514 of 9486
try resetting your sat instead?
post #6515 of 9486
Originally Posted by MadMyers View Post
Interesting question. I really don't think anyone has authoritatively stated the 818 will not pass through 4k content. I haven't done an exhaustive search, however, so if someone can provide a link that states otherwise... I'd like to see it.
Here are some facts I've dug up or know...
1) HDMI 1.4 only supports 4k content at 24 fps
2) HDMI 1.4 supports a TMDS rate of 340 MHz
3) So 4k 24 fps content fits within a TMDS rate of 340 MHz
What's interesting is that the 818 reports a much higher TMDS clock when no output device is connected.
4) Onkyo TX-NR818 reports the TDMS clock of 700 MHz
What does this mean given HDMI 1.4 max is 340 MHz? Perhaps it truly does mean that, if an HDMI cable were to have > 24 fps 4k content the 818 would handle it.
5) Given the 818 indicates such a high TDMS rate as input, one might suspect it can passthrough 340 MHz 4k 24fps content
Nothing conclusive above, just some info that makes me think it may be possible. Too bad very few people have the ability to source 4k content as well as display it!
(BTW, the 818 reduces the advertised TMDS rate when you connect a display. It may be using the value the display supports)
edit: fixed small typed
Ask Onkyo directly here:
http://forums.onkyousa.com/viewforum.php?f=2&sid=478dba5f8fdaceee00f73d101f184090
post #6516 of 9486
I am thinking of buying this a/v.
In the previous line of a/v's , onkyo had same important issues regarding quality control/manufacturing issues (hdmi boards , channel sockets etc).
Is this the case with 818 or it isi significally improved?Any knows issues/malfunctions i should now about?
I am aware of the 24p issue , but i think it is fixed with the latest fw , correct?
thanks in advance.
post #6517 of 9486
I can't remember reading of any HDMI board failures with the 818 in almost 1 year since its introduction. But, it seems that in previous generations they seemed to show up in bunches near the end of the 2 year warranty.
Correct
thanks in advance.
post #6518 of 9486
Quick question. Attempting to use Spotify or Pandora is excruciatingly slow. Both using the onscreen menu and the iOS app. Is this normal or is there a known fix? I have a new 818 with latest firmware, hardwired and using FIOS.
post #6519 of 9486
I never thought of it as slow, but the first connection will take a while. After that, songs buffer and queue quite quickly.
What stage is it slow? Connecting or buffering?
Turning on network standby might help here too, if the receiver is stuck on "initializing" every time you go to the NET input.
post #6520 of 9486
Yep, network standby is on. Every stage is slow for me. Checked Ethernet connection and I pull down 85mbps at its location. I'll try a reset of the unit. Could this be a hardware issue at all? Thanks.
post #6521 of 9486
That's my review and doesn't mention gapless that I recall. I need to update that review at some point because you no longer have to request the FW from Onkyo, you just need to download it from their support page.
I suppose in hindsight I would bump the 818 to 3.5 stars now that they've addressed the 24P issue... however, they lose a star for making me go through hell in my efforts to get it fixed.
post #6522 of 9486
Yeah, definitely update it. For some reason I kept thinking this was the issue everyone was talking about here. So I suppose there still isn't a fix for gapless playthrough of music?
post #6523 of 9486
No idea as I don't play gapless music through my 818. I have a Squeezebox for that and it does the job perfectly.
post #6524 of 9486
Thanks Mad Myers....I tried the sequence of turning on everthing.in the order you suggeted..it worked....i quit griping.....now...do i need to constanly update the firmware? what happens if I don't.... the old Onkyo from 20 years ago...not a way...the Denon I got 5 years ago...never...all i see now is FIRMWARE UPDATES....can someone explain this?
post #6525 of 9486
The technology has changed so much...Firmware updates started happening roughly 5 years ago - at least at this level of technology and at a more frequent pace. It's actually a good thing and a bad thing. The BAD - The manufacturers can put out a non-fully tested piece of hardware to beat the technology curve. The GOOD - At least the updates can fix issues and/or actually enhance the receivers features. Neither is perfect...but I do prefer the later since a fix is usually in the works and you aren't stuck with a piece of hardware that is just functionally out of date.
post #6526 of 9486
Glad to hear it helped.
As for the updates... Well... Your old Onkyo and your Denon probably were not running Linux, didn't have a network stack (for IP communication), and so on. Is this a legit reason for releasing buggy firmware? No. it's simply representative of the state of the industry now.
I'd bet money there will be no more updates to the 818. I'd suggest updating to the latest on their site and be done with it.
FWIW, my upgrade process was:
1) Original firmware
2) Network upgrade to whatever it was they have out there
3) USB upgrade to the 1110-xxxx (24fps bug fix, plus other fixes)
I've not moved to the 1120-xxxx version but don't see any reason for someone who isn't on 1110 to not go there.
post #6527 of 9486
IMO, the current state - where it is possible to update FW in the field - is better. Yes, it can encourage a ship-now-fix-later mentality, but those older AVRs also shipped with bugs (although given the lower complexity, probably fewer (less code = less bugs smile.gif)). We just had to live with it, or ship the AVR to a servicing center if the issue was severe enough for the OEM to care. At least now we have the ability to request change, and apply that change w/o incurring any hard costs.
For e.g. I have an older Denon that doesn't handle HDCP properly, there is a FW fix available but I'd have to pay to ship it and most likely pay to have them update the FW because it's out of warranty.
post #6528 of 9486
GREAT,,,,my old DENON died so I replaced It 818..back to my old buddy...Thanks for the Firmware answer because I just replaced or added to my Home Theatre to the point where the $$$ hagleling/research has burned me out ,,,then I have had to keep asking new kind of questions and i am a soundman for bands since 1975...iv'e run sound for Wet Willie,Hall oats,Tommy Tutone,Nitty Griity Dirtband....so I should know this stuff because i have always had the low-top of the line stuff...Thanks AGAIN!!
post #6529 of 9486
Deal Alert.
Newegg has the TX-NR818 for $559 plus free shipping!! I had just ordered the 809, last week from the Amazon deal of $522.99 So for $37 more bucks you can get the 818.
Promo Code
BTEXSVL67
URL: http://www.newegg.com/Product/Product.aspx?Item=N82E16882120206
You have to login to see the discount! I am in CA so had to pay tax from Newegg. $602.99 with 3 day shipping!
Good Luck. Now after reading all 174 pages of the TX-NR809 owners thread, I get to read all 218 pages on this thread. Woo Woo.
Kirk
Edited by CappyKD - 4/29/13 at 2:37pm
post #6530 of 9486
Originally Posted by CappyKD View Post
Deal Alert.
Newegg has the TX-NR818 for [MM:edited out price --- insert insane price] plus free shipping!! I has just ordered the 809 last week from the Amazon deal of $522.99 So for $37 more bucks you can get the 818.
Promo Code
BTEXSVL67
You have to login to see the discount! I am in CA so had to pay tax from Newegg. [MM:$$$] with 3 day shipping!
Kirk
Because this seemed amazing, i tried it out. Unfortunately I got "Your email address is not valid for redemption of promo code BTEXSVL67." So either it's a one use code or has other restrictions...
post #6531 of 9486
Worked for me. Got to the secure checkout with the discount...Can't do it though. It's an amazing price but I can't justify it since I bought the sony1030 6 months ago. Unreal price and so tempting.
post #6532 of 9486
Odd that it worked for one of you and not another. Hmm.
Nice that the mods or site commented out the price from my post. Am I breaking the rules by posting the price? Hmm,
Kirk
post #6533 of 9486
Newegg code worked for me.
post #6534 of 9486
Kirk
Code works for me. It seems that you have to be signed up to receive promo emails from newegg...Or something...I wish I needed/had room for another 818.
post #6535 of 9486
Deal Alert.
Newegg has the TX-NR818 for $559 plus free shipping!! I has just ordered the 809 last week from the Amazon deal of $522.99 So for $37 more bucks you can get the 818.
Promo Code
BTEXSVL67
Kirk
Worked for me. Just paid $800 for an 818 a couple weeks ago. Just my bad luck.
post #6536 of 9486
Kirk
Didn't work for me. I believe it is email specific.
post #6537 of 9486
Deal Alert.
Promo Code
BTEXSVL67
Kirk
Thanks a lot! The code worked! This is one hell of a deal for this receiver brand new. I also paid $.99 extra to get 3 day shipping. Looks like my home theater system is complete. biggrin.gif
post #6538 of 9486
Happy to help all those that want the deal!!
To those having trouble getting it working. Sign up for the (Newegg) email deals and offers first,then try it again. This code only seems to work for those signed up for email notification.
Two forty off of the normal new egg sale price is a GREAT deal. I'm now glad that I didn't setup my 809 this weekend. Glad I read that email today too.
Kirk
post #6539 of 9486
So i just created an account with Newegg and the code didn't work frown.gif my email is not eligible
post #6540 of 9486
You need to sign up for the emails from new egg first!
G/L
Kirk
