AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo TX-NR818 "official" owner's thread discussion
Onkyo TX-NR818 "official" owner's thread discussion - Page 260
post #7771 of 9512
I am installing a new 818 reciever in my hometheater and it's givieng a strange error in XT32 setup...alll the speakers but the front 2 Bps show up after the first pass of the tones,and thats as far as it will go,says "retry or cancel " . Ive try-ed various troubleshooting,swapped polarity on the front 2,unhooked the back side of the Bps, [their bi-poller].different Mic,etc. I even swapped the front right and the center on the back of the receiver,the problem followed the speaker now the Right showed up but no "cent:eek:er" any idea"s
post #7772 of 9512
Do the speakers work without running the auto setup? are you sure wires are connected properly?
post #7773 of 9512
Sounds like an issue with the FL/FR speakers. If not external, then likely an internal wiring issue. Visually inspect the speaker cable wiring at both ends. If still no joy, then I'd give Def Tech a call for repair.
post #7774 of 9512
Reset the unit? hopefully it is nothing but a software glitch.
post #7775 of 9512
Done did the reset,no difference...:-{ .The speakers work and sound fine,they just show " error" on the setup screen on the Audyssey setup read out one the first screen after the inasille scan. I thought maybe the front chip was bad but like I said I swaped the wires for the RF and Center speakers on the back of the 818 and then it read the center that was hooked up tothe RF output but not the BP30 hookedto the center ?The sound is great but the XT32 was the main attraction to upgrade from my old reciever
post #7776 of 9512
Try different speakers at the failing location.
How does your system work with the speakers configured as 2.0 or 2.1?
post #7777 of 9512
system works fine,just wont give me the audyessy setup,ie the speakers all work and sound fine,I can manulelly setup distance,crossover,ect just won't work with the audyssy
post #7778 of 9512
since you moved the speaker to a different output and the problem followed it would seem Audyssey is having issues hearing your speakers.  not sure why though
post #7779 of 9512
Are the tweeters ok in the failing speakers?
You will get the sound squawk from the XT32 setup but it won't detect the speakers correctly.
post #7780 of 9512
Had the same problem in the past, an error from Audyssey and guess what , 2 blown tweeters i did not know. Bought these speakers from Ebay and during the Audyssey setup it came up with errors on the front speakers. Thanks mr. seller.........
post #7781 of 9512
I am still having issues with my 818s HDMI imputs. After a while the volume tapers off a d gets weak. I can take the same source and put into another imput and the volume triples. Problem is that I am running out of inputs. I am getting ready to reset the entire unit and see if it is corrected and was suggested to me. The only other option is to ship it to Michigan from La. For service since that's the closest. For one thing there's no telling how long it will be gone and if it can be fixed. Then the shipping cost of this monster! Hoe the reset works but I hate to lose all my settings.
post #7782 of 9512
I set up my 818 and connected it to the Internet via wireless to use pandora, spotify, etc to stream music. Everything worked fine. I logged in last week and checked my wireless status and it shows connected at 84 pct but when I try to log into any of my spotify or other music accounts, I get an error message which tells me to check my accounts. I refreshed the wireless connection and also checked my accounts and the accounts are correct in terms of username and password.
Anyone else experience this issue and know how to resolve it?
post #7783 of 9512
new 818 owner here. picked up a refurb reasonable.
i tried several receivers before settling on this for now.
I was looking for something that would do music well along with movies. I was willing to go $2000, but really unless you spend $4500 or so seems like none of the mid-range AV receivers do music very well.
a friend has an older Denon 5803 (5308?) with mods (XT32) that does very well for music, about 4.5K tho, and the mod was $1K plus install.
next I tried an Marantz 7008, it was a bit more musical, but not the sound I was looking for. thinner in the bass, highs were better, still..no cigar, sent it back.
I needed something to watch movies at this point, so i picked up an 818 and it's my favorite of all of them with my Usher S520/S525 setup. they are not expensive speakers, but with the Ushers I can easily hear the difference in amplifiers. it was pretty drastic.
still not exactly what i would like, the 818 bass is just a tad fat, and the highs are not smooth and airy as I have heard on my speakers, but this was with 3k-4k of 2-channel electronics. still, it's the most musical of all the 2k or less receivers I have tried.
The XT32 on the 818 didn't seem to clean up the bass hump in my room as well as the Denon/Marantz did. Audyssey sets my xover for 40hz. i can mess with that.
for music late at night I use Direct or Pure mode anyway. Is there a way to just go to Pure or Direct mode or do I have to cycle through all the different surround modes?
strange how in Pure mode the HDMI still outputs a signal to the TV, I figured it would shut down all video completely.
I am considering the 929 at this point.
post #7784 of 9512
Originally Posted by myoda View Post
Even though Onkyo added some features to the 828, they also left out a few features compared to the 818. I doubt you'll need the 4K passthru anytime soon (the 818 will pass a 4K signal also). The 818 is no slouch for music.
How will the 818 pass through a 4k signal? i thought the 818 couldn't do that..
post #7785 of 9512
You do know that pure and direct do not use audyssey right, therefore no eq at all in those modes.
post #7786 of 9512
there is a way to save the settings I cannot recall how though, but only issue with that is if the problem/glitch is in your settings then it might return after a factory reset.
post #7787 of 9512
yes, correct.
post #7788 of 9512
Hit the home button on the remote, select listening mode, music, left or right arrow till you get to Pure Audio. Then push enter to set the mode.
post #7789 of 9512
You
You can also use the Onkyo app if you have an iPad or iPhone, great app! I do not know if it is in the Android store or OT.
post #7790 of 9512
You
my iPad is loaned out to a friend in a hospital, may try that later. i may just program my harmony remote to several activities, and have one a direct or pure mode. looks like a way to do it after looking over the setup. liking the 818 so for.
post #7791 of 9512
I know it's still way to early to tell yet on the likeliness of hdmi board failure with the 818, but has there been any reports of such. mine is still going strong. I use it every day with at least 6-8hrs of operation so it has some hrs on it.
post #7792 of 9512
818 initial setup questions:
Here's a noob question: I might have others later, some of them definitely embarrassing, but I am stuck at a very preliminary stage of set-up (audyssey multeq xt 32), and the manual does not always offer me any straight answers on a number of issues so I thought I should just come here and ask the experts, or those who know more about this machine than I do:
Here is the first question: I am trying to do the initial audyssey speaker set up with the speakers wired to an external amp (En Emotiva xpa 5)...
I notice, first of all, that I cannot use any 12 volt triggers on the 818 to turn the amp off and on... Is that normal with the 818?
Is there any workaround for this? I am soon going to get a Logitech Ultimate harmony Universal remote: does anyone know whether it can turn an Emotiva xpa 5 off and on?
Edited by sahmen - 9/8/13 at 5:43pm
post #7793 of 9512
i have a question to all u nr818 owners, i own one too as many of u know(iv been very active during the beginning stage of this thread, and i was thinking about 4K TVs, so are we all basically screwed in regards to 4k? because our nr818 can't passthrough a 4k signal, so how are we going to make the switch to 4k? seems like we'll need to get a new receiver..
post #7794 of 9512
Quick question,
I am running my htpc and directv through a Lumagen 2021. I am having an issue with not being able to cycle thru sound format. It seems to stay on THX. Dolby digital IIx and PCM is also lit. I can't get to DTS HD and the like.
Is it the PCM setting? Lost!
post #7795 of 9512
Yeah this would be easy to do with the Harmony and use it over the cumbersome ipad.
post #7796 of 9512
Mine failed 2 months into its life.
post #7797 of 9512
Yes you can you setup the xpa as a zone 2 or zone 3 and it will turn off. Please google onkyo trigger setup and it has step by step directions.
post #7798 of 9512
Do we not have passthrough 4k, I could of sworn I seen something in the menu's one night.
Edit: I think it only upscales to 4k....bummer eek.gif
post #7799 of 9512
Does upgrading the firmware wipe out the Audyssey settings or any other settings?
post #7800 of 9512
Nope. I just upgraded to the latest firmware and it kept everything as it was before.
