Originally Posted by
Digital_Chris
Ok, FOH, I'll give it a shot
What are your thoughts on using a low power plate amp for a higher RMS driver? What filler subs did you pickup to compliment your IB?
Regarding the lower power amp, if the amp is powering a small sealed approach, then you'll need as much amp as possible, .. any more specifics? edit; I see the mention of the Dayton 15", good idea, I've no experience with them but they're quite popular so info should be plentiful. Also, wrt amps, maybe the INukes, or Crowns may have phase/distance manipulation in their onboard DSP. I'm likely going to utilize a dsp loudspeaker processor from Symetrix. Thus enabling individual control over each sub freq, EQ, high, low pass, delay, etc.
I picked up two Seaton SubMersives for both added operational headroom, and for "filler" duty mitigating whatever response issues I encounter in the freq domain. I've yet to integrate them as I'm a bit under the weather right now. Havn't even opened them up yet,...
it's killing me.
Best of luck
Edited by FOH - 7/17/12 at 12:29pm
