This is a car audio related problem, and yet I know from reading this particular forum that I might get a better answer here than on a car audio forum because it's about speaker theory. So bear with me, please
I have a 6.5" component speaker behind the factory grill in the bottom of a door panel. The original factory spacers were 1" off the door itself, but because it would not work, the installer used a 1/2" spacer. So now there is more of a cavity between the speaker and the door panel grill than there needs to be.
The tweeters in the component set (installed higher up the door) are overly bright even after attenuating them with the crossover. What I'm wondering is if a 1" spacer, which would bring the 6.5" driver closer to the grill by only .5 inches, would give the midrange a little more presence, thus slightly offsetting the brightness of the tweeters. And I wondered whether or not any additional undesirable (and audible) reflections are likely being introduced by having the speaker back further away from the grill.
I don't trust myself to change out the spacer, which is why I'm asking you guys before I pay an installer.
