Hello,
I did a basement remodel last year, and took the opportunity to run lots of wiring in the walls to a central closet. For the most part its all working great. The only problem, is that this weekend I broke down and bought an xbox Kinect, and when I plugged it into the in-wall USB extension, it didn't work. Upon examination, I realized I put the upstream sIde at the wrong end. Is there any way to salvage this screw up?
Steve
Steve
