AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Panasonic DMP-BD 35
Panasonic DMP-BD 35
post #1 of 3
Need Help!
I have the above blu ray player (firmware version 1.5)
Vid Camera - Canon VIXIA HF100
External Blu Ray Player:
ATAPI iHBS212 2:
Firmware Revision: 5L09
Interconnect: USB
Burn Support: Yes (Generic Drive Support)
Profile Path: None
Cache: 8192 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW
BD-Write: -R, -RE
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: Insert media and refresh to show available burn speeds
Downloading video from SD Card to Mac.
Mac OS X 10.5.8
2 GHz Intel Core 2 Duo
Utilizing iMovie to import videos and clean up
Then importing to Roxio Toast to ultimately burn movies.
Issue:
Movies burn to disc.
However when I play them on my Blu Ray player NO Picture, just sound.
Have been on the Roxio Toast help area . . . they advised some changes.
Did those, same results
Utilized a Mac Forums blog . . . advised some changes, similar to Roxio's same results.
Confirmed video is on discs as they do play through my Mac.
Just don't play on my Blu Ray Player.
Burning to Verbatim BD-R 25 GB 6x speed.
Any help would be greatly appreciated . . . spent many dollars and now time trying to figure this out!
post #2 of 3
Welcome. Please post all questions to the BD35 thread. You should be able to find the files that Panasonic supports in the owner's manual. Video support is limited.
http://www.avsforum.com/avs-vb/showt...75161&page=493
S~
post #3 of 3
Originally Posted by Gupsdad View Post
Need Help!
ATAPI iHBS212 2:
Interconnect: USB
Profile Path: None
Cache: 8192 KB
Reads DVD: Yes
CD-Write: -R, -RW
BD-Write: -R, -RE
Mac OS X 10.5.8
Issue:
Is it possible you are creating an Apple proprietary format movie disc that the Panasonic cannot handle? Are you building a proper standard BD-R BDMV format movie disc?
btw - do yourself a favor and pick up a handful of rewritable BD-Rs for testing and experimenting. I use some Fuji brand that were about $3 each in a package of 5 and they work fine. Check EBay and/or Amazon.
