AVS › AVS Forum › A/V Control & Automation › Home Automation › Crestron Adagio XM card
post #1 of 2
About a month ago the XM card on my Adagio stopped working/picking up the satellite signal. To that point, it'd pretty much worked flawlessly and there were no changes to the system. Is there a diagnostic I can check to see if the card needs to be replaced or if there is some other hitch in the system?
Is this something my programmer can look at?
post #2 of 2
Your programmer should be able to look at signal strength/confirm that the card is reporting in the frame properly.
If possible confirm the connection of the XM Ant. to the card, the stupid little SMB-type connectors are easily knocked loose. If feasible plug a different Ant. in, you should at least get some of the terrestrial signal (depending on where you live/how deep in your house you are) if the card is functioning.
  Back to Forum: Home Automation
