AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › #### The ULTIMATE Bass Demo Disc ####
#### The ULTIMATE Bass Demo Disc #### - Page 23
post #661 of 852
Originally Posted by bigvix View Post
We should have someone start burning these to Blu-ray and selling them to members smile.gif
I got it downloaded but waiting on my Blue-Ray burner and disks to arrive!
post #662 of 852
Originally Posted by Jindrak View Post
Listing for Volume 2:
I just wanted to point out that you forgot the Super 8 train crash scene in that listing.
post #663 of 852
Cant delete this post...
post #664 of 852
Originally Posted by nickbuol View Post
Good point! Sorry!
post #665 of 852
Which means it's not on Leo's wonderful box cover, either. :(
post #666 of 852
I think the super 8 crash is one of the scenes he said that was corrupted/buggered up.
post #667 of 852
I see! Well it's playing fine on XBMC, haven't tried burning the blu-ray.
post #668 of 852
By the way if anyone needs it, I can provide a mapping between the scene titles and the .m2ts files in the STREAM folder for both volume 1 and volume 2.
post #669 of 852
I would love to find out how to play an ISO file with XBMC frodo 12.2
I am still very new at XBMC and trying to figure it out. Any help would be nice
post #670 of 852
That would be great neutro!
post #671 of 852
Originally Posted by Slingblayde View Post
Will it unpack the ISO, fix the files, then repack it back to an ISO? Ive always wondered how to update or fix something in an ISO file, like a live Antivirus disc I have, its a year old, how do I update the virus definitions on it so that when I work on a PC I know I have just about the latest and greatest Def's.
I apologize for the incomplete information!
PPF-O-MATIC is only good if you already have a patch to apply, it does not generate one for you.
Here's a tool that does the job:
xdelta
xdeltagui
Run the GUI, click Settings>Paths, and select xdelta file you downloaded (in my case I chose 'xdelta3-3.0.7.x86-64.exe').
Here's how you create a patch (diff) file:
File 1 is the original ISO we already downloaded
File 2 is the new ISO you created after fixing issues
Patch is any filename you choose
Click MAKE to create the patch file.
Then, you can either upload the patch file to the forum, or any file hosting website, or create another torrent.
Here's how we can apply the patch (diff) file to the existing ISO file we already downloaded:
Original File: We select the ISO we already downloaded
Patch: We select the patch/diff file you uploaded using above procedure
New File: We select a filename to write the modified ISO to
We click APPLY.
I've only tested on a ~100MB file, this should work on huge ISO files as well, and I would think the x64 version is more capable than the 32bit one.
The patch file created was only 772 bytes in size! Much better than re-uploading the whole 100MB corrected MP4... smile.gif
Feel free to ask questions.
Edited by shpitz - 11/26/13 at 8:56am
post #672 of 852
I'll try to post that tonight!
post #673 of 852
I think you just have to select it and hit play smile.gif You'll get a dialog asking if you want to browse the folder substructure or launch the menu. With blu-rays though, menu support is spotty with XBMC. And I think you have to use the keyboard to navigate the menus (the mouse won't do it).
I find it easier to browse the BDMV/STREAM folder and play the individual .m2ts files. So I just mounted the ISO and copied the folder structure.
post #674 of 852
There's a way doing this with an external player (TMT in this example).
Follow instructions here and http://forum.xbmc.org/showthread.php?tid=116724&pid=1324236#pid1324236
Easiest solution, if you don't care for previews and extras, is to just remux the movie into an MKV, then playback is easy smile.gif
post #675 of 852
I agree with shpitz. Makemkv is super easy and you just mount the whole ISO and then "re-rip" it into a .MKV and are done. You will need to create whatever metadata and images you want, or let whatever tools you have do screen grabs, but that is easier than worrying about external players and such if you aren't going to use them for anything else.
post #676 of 852
Ember is my favorite media manager: here
post #677 of 852
Yeah, I'm using Media Center Master with pretty good success.
post #678 of 852
Here are the track listing corresponding to each .m2ts file in the two volumes.
Volume 1 is pretty straightforward:
01 - Avatar - Destruction of Hometree -> BDMV/STREAM/00000.m2ts
02 - Batman: Under the Red Hood - First Five Minutes -> BDMV/STREAM/00001.m2ts
03 - Battle: Los Angeles - Final Battle -> BDMV/STREAM/00002.m2ts
04 - Battle: Los Angeles - Gas Station -> BDMV/STREAM/00003.m2ts
05 - Battle: Los Angeles - Hell Ride to Santa Monica -> BDMV/STREAM/00004.m2ts
06 - Black Hawk Down - ****ing Irene -> BDMV/STREAM/00005.m2ts
07 - Cloverfield - First Attack -> BDMV/STREAM/00006.m2ts
08 - Cloverfield - Street Crossfire -> BDMV/STREAM/00007.m2ts
09 - Fellowship of the Ring - Sauron Defeated -> BDMV/STREAM/00008.m2ts
10 - Flight of the Phoenix - Plane Crash -> BDMV/STREAM/00009.m2ts
11 - Harry Potter and the Deathly Hallows Part 2 - Stone Guardian -> BDMV/STREAM/00010.m2ts
12 - Hellboy II - Elemental Battle -> BDMV/STREAM/00011.m2ts
13 - How to Train Your Dragon - Super Dragon -> BDMV/STREAM/00012.m2ts
14 - Immortals - Mountain Destruction -> BDMV/STREAM/00013.m2ts
15 - Immortals - Tidal Wave -> BDMV/STREAM/00014.m2ts
16 - Inception - How Did You Get There -> BDMV/STREAM/00015.m2ts
17 - I, Robot - Spooner Attacked in His Car -> BDMV/STREAM/00016.m2ts
18 - Iron Man - Cave Escape -> BDMV/STREAM/00017.m2ts
19 - Iron Man - Jericho Missile -> BDMV/STREAM/00018.m2ts
20 - Iron Man 2 - Creating a New Element -> BDMV/STREAM/00019.m2ts
21 - Iron Man 2 - Intro Fly In -> BDMV/STREAM/00020.m2ts
22 - Jurassic Park - T-Rex Appears -> BDMV/STREAM/00021.m2ts
23 - Knowing - Plane Crash -> BDMV/STREAM/00022.m2ts
24 - Kung Fu Panda - Skadoosh -> BDMV/STREAM/00023.m2ts
25 - The Last Airbender - Waterwall -> BDMV/STREAM/00024.m2ts
26 - Live Free or Die Hard - Appartment Shootout -> BDMV/STREAM/00025.m2ts
27 - Live Free or Die Hard - F-35 Attacks -> BDMV/STREAM/00026.m2ts
28 - Live Free or Die Hard - Tunnel Catastrophe -> BDMV/STREAM/00027.m2ts
29 - Lords of the Ring - Gandalf vs Balrog -> BDMV/STREAM/00028.m2ts
30 - Mission Impossible: Ghost Protocol - Kremlin Explosion -> BDMV/STREAM/00029.m2ts
31 - Master and Commander - First Attack -> BDMV/STREAM/00030.m2ts
32 - Open Range - Showdown -> BDMV/STREAM/00031.m2ts
33 - Pulse - Server Room -> BDMV/STREAM/00032.m2ts
34 - Resident Evil: Afterlife - Tokyo Purge -> BDMV/STREAM/00033.m2ts
35 - Scott Pilgrim - The Twins Battle -> BDMV/STREAM/00034.m2ts
36 - Serenity - Reaver Chase -> BDMV/STREAM/00035.m2ts
37 - Terminator: Salvation - Gas Station Attack -> BDMV/STREAM/00036.m2ts
38 - The Dark Knight - Bank Robbery -> BDMV/STREAM/00037.m2ts
39 - The Dark Knight - Hospital Explosion -> BDMV/STREAM/00038.m2ts
40 - The Dark Knight - Lau's Extraction -> BDMV/STREAM/00039.m2ts
41 - The Hurt Locker - Beginning Explosion -> BDMV/STREAM/00040.m2ts
42 - The Incredible Hulk - Sonic Cannons -> BDMV/STREAM/00041.m2ts
43 - The Incredible Hulk - Street Fight -> BDMV/STREAM/00042.m2ts
44 - The Matrix: Revolutions - Burly Brawl (damaged) -> BDMV/STREAM/00043.m2ts
45 - The New Daughter - Into the Hole -> BDMV/STREAM/00044.m2ts
46 - Toy Story 2 - Intro -> BDMV/STREAM/00045.m2ts
47 - Transformers - Base Attack -> BDMV/STREAM/00046.m2ts
48 - Transformers - Ironhide Jump -> BDMV/STREAM/00047.m2ts
49 - Tron: Legacy - Disc Wars -> BDMV/STREAM/00048.m2ts
50 - Tron: Legacy - Entering the Grid -> BDMV/STREAM/00049.m2ts
51 - Tron: Legacy - Lightcycle Battle -> BDMV/STREAM/00050.m2ts
52 - Tron: Legacy - Plane Battle -> BDMV/STREAM/00051.m2ts
53 - U-571 - First Depth Charges -> BDMV/STREAM/00052.m2ts
54 - War of the Worlds - Lightning Strikes -> BDMV/STREAM/00053.m2ts
55 - War of the Worlds - Military Fights Back -> BDMV/STREAM/00054.m2ts
56 - War of the Worlds - Plane Crash -> BDMV/STREAM/00055.m2ts
57 - War of the Worlds - Pods Emerge -> BDMV/STREAM/00056.m2ts
58 - X-Men: First Class - Eric Turns the Parabolic Dish -> BDMV/STREAM/00057.m2ts
59 - X-Men: First Class - Little Eric -> BDMV/STREAM/00058.m2ts
60 - Dolby - Bit Harvest -> BDMV/STREAM/00059.m2ts
61 - Dolby - Countdown V2 -> BDMV/STREAM/00060.m2ts
62 - Dolby - Spheres -> BDMV/STREAM/00061.m2ts
63 - DTS - SFX (Long Version) -> BDMV/STREAM/00062.m2ts
64 - Imax - Intro -> BDMV/STREAM/00063.m2ts
65 - THX - Amazing Life -> BDMV/STREAM/00064.m2ts
66 - THX - Broadway (Classic) -> BDMV/STREAM/00065.m2ts
Volume 2 has some quirks (e.g 28 Weeks Later is 00000.m2ts):
01 - 9 - 9 Awakens -> BDMV/STREAM/00001.m2ts
02 - 9 - Blowing up the Factory -> BDMV/STREAM/00002.m2ts
03 - 9 - The Beast -> BDMV/STREAM/00003.m2ts
04 - 9 - The End -> BDMV/STREAM/00004.m2ts
05 - 9 - The Flying Beast -> BDMV/STREAM/00005.m2ts
06 - 9 - The Machine Still Lives -> BDMV/STREAM/00006.m2ts
07 - 9 - When We Awoke, it was Chaos -> BDMV/STREAM/00007.m2ts
08 - 28 Days Later - City Firebombing -> BDMV/STREAM/00000.m2ts
09 - Dark Knight Rises - Crashing the plane -> BDMV/STREAM/00008.m2ts
10 - Dark Knight Rises - The Bat -> BDMV/STREAM/00009.m2ts
11 - Dredd - Miniguns -> BDMV/STREAM/00010.m2ts
12 - Fight Club - Intro Scene -> BDMV/STREAM/00011.m2ts
13 - Fight Club - Why wasn't I told -> BDMV/STREAM/00012.m2ts
14 - Halo 4 - Capture the flag -> BDMV/STREAM/00013.m2ts
15 - Halo 4 - Final Fight -> BDMV/STREAM/00014.m2ts
16 - Halo 4 - Intro -> BDMV/STREAM/00015.m2ts
17 - Halo 4 - The Attack Begins -> BDMV/STREAM/00016.m2ts
18 - Halo 4 - The Warthog -> BDMV/STREAM/00017.m2ts
19 - Hitman - Cheap Guns -> BDMV/STREAM/00018.m2ts
20 - Hot Fuzz - Big Gun Battle -> BDMV/STREAM/00019.m2ts
21 - Hot Fuzz - Decapitated -> BDMV/STREAM/00020.m2ts
22 - Hot Fuzz - Fist Fight -> BDMV/STREAM/00021.m2ts
23 - Hot Fuzz - Preparing for war -> BDMV/STREAM/00022.m2ts
24 - Looper - Can't Kill Yourself -> BDMV/STREAM/00023.m2ts
25 - Looper - Future Joe Rampage -> BDMV/STREAM/00024.m2ts
26 - Looper - Intro -> BDMV/STREAM/00025.m2ts
27 - Looper - Telekinetic Explosion -> BDMV/STREAM/00026.m2ts
28 - Looper - The Rain Kid -> BDMV/STREAM/00027.m2ts
29 - Percy Jackson - Surprise at the bonfire -> BDMV/STREAM/00028.m2ts
30 - Rambo - The Bomb Explodes -> BDMV/STREAM/00029.m2ts
31 - Rambo - Final Fight -> BDMV/STREAM/00030.m2ts
32 - Redline - End of the 1st Race -> BDMV/STREAM/00031.m2ts
33 - Redline - Intro -> BDMV/STREAM/00032.m2ts
34 - Return of the King - Destruction of Mt. Doom -> BDMV/STREAM/00033.m2ts
35 - Sherlock Holmes: A Game of Shadows - How many windows must I provide -> BDMV/STREAM/00034.m2ts
36 - Sherlock Holmes: A Game of Shadows - Moonlight Assassin -> BDMV/STREAM/00035.m2ts
37 - Sherlock Holmes: A Game of Shadows - Run Away from Moriarty -> BDMV/STREAM/00036.m2ts
38 - Skyfall - Destruction of Skyfall -> BDMV/STREAM/00037.m2ts
39 - Skyfall - Subway Train -> BDMV/STREAM/00038.m2ts
40 - Star Trek - Narada emerges from the black hole -> BDMV/STREAM/00039.m2ts
41 - Super 8 - Train Crash -> BDMV/STREAM/00040.m2ts
42 - The Amazing Spiderman - Ending Scene -> BDMV/STREAM/00041.m2ts
43 - The Amazing Spiderman - Sewer Encounter -> BDMV/STREAM/00042.m2ts
44 - The Amazing Spiderman - Subway Jump -> BDMV/STREAM/00043.m2ts
45 - The Expendables - Car Chase -> BDMV/STREAM/00044.m2ts
46 - The Expendables - Killing Pirates -> BDMV/STREAM/00045.m2ts
47 - Total Recall - Final Battle -> BDMV/STREAM/00046.m2ts
48 - Total Recall - Through the Core -> BDMV/STREAM/00047.m2ts
49 - Total Recall - You're a Spy -> BDMV/STREAM/00048.m2ts
50 - Underworld: Awakening - Intro -> BDMV/STREAM/00049.m2ts
51 - Underworld: Awakening - Super Lycan Fight -> BDMV/STREAM/00050.m2ts
52 - Underworld: Awakening - They Found Us -> BDMV/STREAM/00051.m2ts
53 - Underworld: Awakening - Why So Angry -> BDMV/STREAM/00052.m2ts
Hope that helps.
post #679 of 852
Having problems burning the .iso file.
First disk said something about the file was burning to fast.
Second one it said it had an error and would not verify disk.
Is there a certain program everybody is using?
I'm just clicking on the file. It picks the drive where the burner is at. And then executes, but with errors.
post #680 of 852
Imgburn
It's free, easy, and it works.
post #681 of 852
Last time I burned a disc was 10 years ago.
Optical media in my eyes is a total fail: too many coasters, lifespan too short, unreliable, time-consuming, expensive.
a 4TB hdd can hold about 80x 50GB discs, sells for ~$150. A blank 50GB BD-R costs ~$4, that's over twice the cost of the HDD. To me, magnetic storage beats any optical media in terms of accessibility, availability, and performance.
The only thing is, with large HDD comes a massive loss when there's failure, but today with RAID, you can even minimize/eliminate the failure aspect of magnetic media.
You can save 10-20% by remuxing into MKV, you don't need to get off the couch to change discs, no time wasted looking for something, waiting for it to load, etc...
My 2c...
Edited by shpitz - 11/27/13 at 12:26pm
post #682 of 852
The only thing is, with large HDD comes a massive loss, but today with RAID, you can even minimize/eliminate the failure aspect of magnetic media.
My 2c...
I like the gigantic HD method also, but for some reason I also like having the physical media. Sometimes I just couldnt be arsed to fire up the HTPC, wait for windows to boot and do all its shenanigans, I like to pop a disc in and play it. I have a 4-bay QNAP NAS box, I slapped four 2T drives in it with raid 5. I end up with just over 5.5T after parity. I like having full 1:1 rip of my blurays on it, but Im still not that good at ripping them, too many settings to read up on, and they seem to have the sound out of sync with the video a lot when I rip and its annoying as hell.
post #683 of 852
Originally Posted by tboe77 View Post
Imgburn
Ended up having to put it on my SSD and use imgburn. Worked great, didn't expect it to take 1.5 hours or so. But glad I got it. Disk works great!
Fiancé' said "what's the point of this disk"
I said "to show off"
She's like... 'Ohhhh"
post #684 of 852
Well, install an SSD as your boot drive and Windows will load up in 10 seconds smile.gif
Or put the PC to sleep instead of shutting down.
post #685 of 852
... or just leave it on!
Not to boast or anything, but I think I found the ideal setup for my use case. I moved my office into the room just under the living room. My desktop computer is only a few feet away (vertically) from my HT setup. So I drilled a hole and directly used an HDMI cable. Thus my receiver + TV is simply a second monitor. I use a cheap IR remote, and a bluetooth keyboard and mouse to navigate my computer. The computer is also the family media server so it's always on. It's got an SSD to boot, so that launching, say, XBMC, is just instantaneous.
The pleasure of having the capabilities of a speedy, complete computer at your fingertips in your HT, without the noise, is astounding. Accessing the various demo disks (including Jindrak's) takes second, and is in fact limited by how fast I can punch the remote to launch XBMC and navigate to my demo folder.
post #686 of 852
Here's the star trek .m2ts that's not buggered up: https://mega.co.nz/#!ME1kkT6R!YueNVTM7ZqLFNl4pmAelgRBHIhFV1pxdxImc4LP0qps
Super 8 coming soon.
post #687 of 852
I have SSD's on my main gaming PC, and my laptop, but I just havent wanted to spend the cash to buy SSD's for all of my other PC's. I want 256 gig drives or better in all of my pcs, but they are still a bit expensive in price/gig at 180 bucks or so plus tax for a 256gig drive, thats almost 1000 bucks just for SSD main drives for my pc's, when I coulda spent that on more electronics for the rack! wink.gif
My laptop I never usually shut down, my main gaming PC I shut off every night but it has a SSD so its fine, Ive been hosting a Teampseak server on one of my spare PC's for about 10 years and it never gets shut down either, but I never turn the HTPC's on unless I want to use them. What I should do is migrate the TS server to one of the HTPC's and leave it on all the time and get rid of the one thats hosting it now. Kill 2 birds with one stone.
post #688 of 852
Did you try producing a diff file from the m2ts? would save you a TON of un-needed data to upload...
post #689 of 852
Thanks a lot for Vol.2 :D
Just finished downloading...and will be seeding for as long as possible :)
post #690 of 852
Thanks.....waiting patiently for the Super 8 scene also ;)
