I think I will call this the Infinity RS HO-No's
4.5 *edit* don't ask me what I was thinking: 3 Cubic foot sealed (before bracing). Amp will be a Berhinger iNuke 3000DSP.
Some observations about the driver:
1. Extremely stiff cone. The rubber surround looks like it is wrapped under itself (no flat lip) to stiffen up the suspension.
2. Really neat trick they did with the cone (see pic). As the cone meets the surround they have it folded over (think ^ shape). IMO that adds a great deal of rigidity and stability
3. Though the basket is stamped it is coated in what looks like a zinc bath. The hole edges are folded for rigidity and were the basket meets the magnet and spider it is vented. Everything about this speaker speaks to rigidity and stiffness.
4. Vented pole piece
Infinity has seemingly brought a lot of technology to this budget woofer.
Actually they are well suited to either music or HT.
Was the 113dB for the final product of 4 of these with 1400W? That would line up much closer (in fact it's almost exact if I use the F10 frequency of 22.69hz, 4 drivers and 1400W shows 113.393dB). Either way it's respectable I just want to make sure I don't have something majorly messed up
Note, in my model the drivers are over XMax at 20hz by 3.5mm also (probably would be fine though). I pulled the parameters from this PDF linked off of the Crutchfield site, page 6:
. Isn't the only difference that the 1260 is single voice coil and the 1262 is dual? They both have 13mm xmax and are xmax limited at 20hz so one shouldn't be putting out more SPL than the other really (same size cone moving the same distance).
