Oh wow I was wrong about the iNuke. Might have to give them a listen as I'll be needing some more amps power soon, was going to just get more XTis.
Originally Posted by Jinjuku
They are quieter but still loud. Think Lawnmower vs Jet Engine
Damping factor is tied to the amount of negative feedback employed. So that metric doesn't necessarily apply. The iNuke 1K and 3K are rated 2 Ohm.
I think the best way is use the iNuke 3000 at two ohm on one channel. That will give you 620 watts RMS (I don't know if this is 20-20K). Use the 1260W (not the 62) and wire for a two ohm load. Then you can always add a 2nd sub later on on channel two. That for roughly $700 is a killer combo.
