Subwoofer of my old logitech 2.1 setup is developing buzzing problems and it's time for a new set. I'm having trouble finding speakers with low ambient noise levels.
Requirements:
Cost: <$250, under 200 would be better
Connection: 3.5mm jack from my computer onboard sound, though it does have an optical out as well
Need surround: No, would rather have better 2.1 setup
Need headphone support: No
Room size: small (~150 sq. ft.)
Usage: Music at low volume, occasional movies at low-mid volume
Manufacturer: not Logitech
Have a new Klipsch Promedia 2.1 sitting in front of me that will probably be returned soon because the noise levels are much higher than my old crappy set even when audio input is unplugged. By noise I mean a static hiss like white-noise (no single-frequency problems). Hiss is audible from 2-3 ft away.
I apparently have better than average hearing (volume-wise), and finding a setup without this hissing is a problem. To give an idea of the volume levels I use, I have windows volume set to 50%, Klipsch speakers set to ~15%, and another external gain control set to 50%. Noise is unaffected by Klipsch volume knob below about 50%, and increases above this. Speakers are 2-3 ft away on my desk, and noise is still audible.
Does anyone have a suggestion for a speaker set with decent quality that is useful at low volumes, or know what to look for in specs to find one with really low hiss noise?
Requirements:
