Already this is again off in the ditch.
First, the distinction between stereo and surround is fundamental to Toole's approach. It is not a trivial distinction.
Secondly the issue is NOT inadequate treatment versus no treatment. Nor is it inadequate treatment versus treatment. Neither Toole nor anyone else of prominence has any significant disagreement there - both issues of which are already at odds with the preponderance of the status quo of this forum simply based upon classic complaint of the forum as to how such expectations are impractical, unreasonable, too expensive, and/or that their wife won’t allow them..
Third, there is another variable that is conveniently left out of most of the discussion - including where it has morphed yet again.
And that is the necessarily predicated upon the use of UNIFORM POWER RESPONSE speakers.
Toole is not talking about rooms or treatment independent of this! And Toole (as well other prominent acousticians) ASSUMES broadband treatment.
It is no surprise that inadequate treatment that is arbitrarily applied that results in coloration and less precise imaging may be perceived as detrimental and DESERVES to be removed - nor is that the proper topic at hand..
And so, of those wanting to debate and share personal impressions, how many here have uniform power response speakers? Right...
If not, you are NOT discussing the ideas presented by Toole. And the use of treatment to control such non-uniform behavior is not at issue.
The issue is NOT about treatment or no treatment as is incorrectly posited. And it certainly is not about measurements or no measurements used to quantify physical behavior in conjunction wit subjective perception, as one continues to misframe it.
Unless you have uniform power response speakers, then Toole himself would not allow you the luxury of treatment or no treatments (assuming a near ideally configured room lacking any focused sparse reflections).
Toole's position is predicated FIRST upon the proper choice of a UNIFORM POWER RESPONSE speaker.
To my knowledge, no one cited debates the issue of treatment required to correct for the effects of real world non uniform power response speakers.
Unfortunately, much of what has taken place in this parody of a debate has been the willy nilly running to hide behind one aspect considered, not in context with, but independently of the other necessary contributory factors. And to the degree that this is done, the arguments are specious.
So, if you want to debate issues of treatment, first examine the prerequisite final response of any model desired, and the presumed per-requisite base configuration that necessarily provides a causal basis for any results.In other words, stop making erroneous assumptions and frame the debate properly.
Edited by dragonfyr - 7/25/12 at 10:06am
But some posts here are nothing but name calling at this point, and it's really tiresome (and a little embarrassing, quite frankly).
