AVS › AVS Forum › Audio › DIY Speakers and Subs › Seeking Guidance -- Update: 2 x FTW-21 + 2 x UXL-18
Seeking Guidance -- Update: 2 x FTW-21 + 2 x UXL-18 - Page 3
post #61 of 74
Scott, what's it gonna take for you to come down to sunny SoCal and setup one of these MINI units? wink.gif
Hey Beast, ya ready for me??!! See ya Sunday!
post #62 of 74
Locked and loaded. Almost. I am pulling the RE's out tonight to reseal around the baffle, re wire to make them capable of using both sets of binding posts so I can adjust series/parallel and mono/stereo configurations outside the box without having to pull the driver (double set of binding posts for each box).
Ill have it all dialed in real nice by the time you get here broski. How hot do you like your bass? Haha
post #63 of 74
AWESOMENESS!!!
post #64 of 74
AWESOMENESS!!!
Beast, just unhook your mains and and feed him strictly dangerous sub-30Hz infrasonic content at +20... You might want to get a legal waiver on file, so he doesn't sue you...
Edogg, call me from the hospital.
post #65 of 74
post #66 of 74
I was going to run them about similar to how you had them set up just so it would be a closer comparison, but ill start it out about how I like it..
post #67 of 74
Popa, how is he gonna be able to call if he can't hear anything you are saying? Conversation might be a little lop-sided
post #68 of 74
post #69 of 74
My bad,
Guess some opinions I've been reading lately had me worrying about his internal organs liquifying. Humans can't technically hear anything below 20hz anyway, right???
lol...
post #70 of 74
I figured you'd need that capability. does it do line boosting from consumer to pro signal as well?
Good question. Umm.... I'm not sure. Probably not. *shrugs*
Originally Posted by audiovideoholic View Post
So, that one unit is all that I will need? What about the box mentioned earlier?
Thanks Scott!
Well, it will accept two independant inputs and has an output matrix to support eight independant outputs/locations. Pretty g'damned impressive, if I may say so.
I am not familar with "the box mentioned earlier". I must have missed that part.
Umm, when I get it I'll let you know. As for what it takes, just takes an invite. biggrin.gif
post #71 of 74
Great! I buy the box, you set it up. Its a win win!!........ Youre welcome! tongue.gifbiggrin.gif
post #72 of 74
For those interested...connections into and out of the 2 x 4 Balanced miniDSP.
post #73 of 74
Originally Posted by VEXXD View Post
For those interested...connections into and out of the 2 x 4 Balanced miniDSP.]
VEXXD,
That is extremely helpful...thanks for posting these pics!
I just ordered a Balanced MiniDSP and these pictures will be a big help to me.
post #74 of 74
Another little tip that I didn't figure out right away (maybe it's obvious to most)...you can pull the phoenix connectors out, making installing the wires a lot easier. When I did the power/input side, I didn't realize they came out so I was struggling with the wires and screws with the connectors plugged in. Remove the connectors, screw in the wires, then plug the connectors back in rolleyes.gif
