I have an older dual core AMD Athlon Brisbane 1.9 cpu on an HP Slimline. I want to make the system quieter but I'm not sure if I should be looking at replacing just the cpu fan or the fan and heatsink. The current stock fan is an Asus 70x70x20mm (specs listed in link below) and the heatsink is also an Asus which is bolted down to the motherboard in a square pattern with screws at all 4 corners.
I have been battling noise in this computer for awhile now. Several months ago it started making a loud pitched whine. The whine would change pitch depending on cpu use. After doing some research I learned about soft mounting and how sometimes the metal screws connecting the fan to the heatsink can cause vibration throughout the case which increases noise. I went ahead and removed the screws and mounted the stock fan to the heatsink using double sided tape on all 4 corners. This immediately lowered the whining noise, so much so that I was kind of shocked. Anyways, over the past week the whining noise has started to come back some, nowhere near as bad as before but enough to annoy me.
According to the specs the stock fan is 5000 RPM with a noise output of 44.3 dB. 5000 RPM is pretty high isn't is? The speed is always the same no matter what I'm doing. I've looked into Speedfan to try to change it but it doesn't do anything. It says the speed is around 2100 RPM but I don't know if that is correct or not. The computer is an OEM HP so no options to change speed in the BIOS. The computer runs pretty hot as it is. Usually 60-75C depending on load. From what I understand these older Slimlines run hot though and I've had the computer for 5 years without any problems.
What fan should I be looking at replacing it with? I want quiet as possible. The options on Newegg for 70mm fans are pretty sparse. From what I understand this size fan isn't really popular so the pickings are slim. Should I be looking at a 80mm fan instead? It wouldn't fit the currect bracket but I could just double sided tape it to the heatsink like I'm doing now couldn't I? There are a lot of quiet and highly rated options in the 120mm range, but that wouldn't fit in my case would it?
I'm trying not to spend any more than $20-30. If a $10 fan would be just as good I'm fine with that. Thanks for any help and suggestions on what I should do.
http://parts.digikey.com/1/parts/172...12dd-tp10.html
Right now it is doubled sided taped at all 4 corners with a 1/4" gap between the fan and heatsink. I did this a few months ago after some research showed that the metal screws were vibrating through the heatsink to the cpu. Every time cpu usage would go up or down a high pitched and extremely irritating whine would occur. I've eliminated that by removing the screws and mounting with x2 sided tape.
That's the point of using a 80mm, 25mm-thick fan instead of a 70mm, 15mm or 20mm-thick fan.
