AVS › AVS Forum › Video Components › Home Theater Computers › HTPC Desktop Case & Tower Cooler?
post #1 of 5
Are there any ATX HTPC or desktop style cases with at least 3 external bays and can fit a 120mm tower cooler? Specifically the Xigmatek Gaia, since that's what I have.
post #2 of 5
Why not use the stock cooler? Good for HTPC and you don't have to limit yourself.
post #3 of 5
Because I'll be using it as more than just an HTPC.
post #4 of 5
Gotcha. Well that helps quite a bit.
Your issue is going to be that most desktop style cases have the optical drive over or abutting the CPU cooler.
Do you need/want an optical drive? If you do then its likely going to be tough to find anything.
post #5 of 5
I'll actually have 2 optical drives, 1 card reader and 2 hard drives. Will need room inside for a GTX 560 Ti.
Still haven't found anything, though it occurred to me a 4u rackmount case might work. Been searching but haven't found one I really like. Ideally it wouldn't have a front door and wouldn't be too deep. The shelf it will be on is only 17" deep. I already cut most of the back out so airflow won't be a problem even if the back of the case is flush with the back of the shelf but I wouldn't want it to hang out over the front by more than 1" or so.
