Originally Posted by zoetmb
But having said all that, what if Apple had a TV that:
- skipped over current tech and had very high resolution - 4K or higher right now
- on the day of release had a store in which you could download/stream 4K movies and TV shows
- created an SDK for apps that could run on the TV and anyone could create and sell them, just as they can for iOS with the usual 70/30 income split.
- used Siri for a large part of interface and control.
- was absolutely seamless when used with other Apple devices.
- automatically recognized and controlled every connected and available device
- had a remote control that seamlessly integrated every other device
- automatically brought or streamed content from any other device to the TV
- instead of isolating each different type of content from a UI perspective, integrated it. So it treated your music library or photo library just like a TV channel.
- had an integrated videophone app with a camera that actually made you look good.
- had a UI that displayed multiple live TV images of different channels - sort of like "Top Sites" in Safari, but with live content.
That and other functionality that I haven't thought of yet might (just might) be enough added extra value to make an Apple TV a success. But the other manufacturers, especially Samsung, would copy them very quickly.
If Apple could do all the above, then why does it need to be a TV? Instead, why not create a set-top box to rule all set-top boxes, and a monitor-only style TV? They could still build a fancy looking TV, just with a separate box for the brains.
This approach would accomplish two big objectives:
1. For the Apple TV itself, much easier to be a thinner device. Also, using some sort of wireless HDMI, would enable a TV that only needs power, no other physical cords going into it. After all, wouldn't it defeat the purpose of a slick looking TV built by Apple if it has HDMI, component, antenna cords going into it?
2. By building a separate box, their target market is everyone with an HDTV, not just those looking to buy a new TV. That's a huge difference no matter how you slice it. It's another hook into the Apple ecosystem, but still leaves room for the Apple TV itself to be a separate platform altogether (i.e., 4K display, high-quality camera, etc.).
