Telescopic Vs. Fixed-length antenna masts
Per the Channel Master Off Air Antenna Installation Guide:
- CM Telescoping Masts - Note: Current models are now made from 18-guage tubing. Older models used to be 16-guage.
- Rohn Telescoping Masts - Note: Top section is 18-guage, lower sections are 16-gauge.
Questions:
A telescoping mast is used in installations for which standard 5 or 10 foot lengths of mast stacked together would not be sufficiently strong or rigid. (1.) A length of telescoping mast is stronger and more rigid than the same lengths made up of standard mast pieces stacked together. Because of their additional strength, some telescoping masts used with ground mounts (2.) can be extended up to 15 feet above the roof line without requiring guy wires. Another advantage of telescoping masts is that they can be (3.) easily adjusted to odd heights without having to cut the tubing.
(4.) For extra strength when installing large antennas, use a telescoping mast that is one size larger than actually needed. This will permit you to attach the antenna to the mast section immediately below the topmost one. This section is larger and stronger than the topmost section because it is reinforced by the 1-1/4 diameter section that remains inside.
Questions:
- Is CM's list of benefits for telescoping masts accurate?
- Are there any disadvantages other than their additonal cost & weight not mentioned by CM?
- Are there other brands worth considering?
