I have seen subwoofers with passive radiators described as sealed and other subs with passive radiators described as vented.
In the Passive Radiator FAQ from Acoustic Elegance they make this statement:
"You typically only want to use a passive radiator along with a woofer that is designed for a vented enclosure. A passive radiator enclosure is NOT a sealed box enclosure. You will typically want to use a lower Q woofer with a PR system. This means a woofer with Qts of .4 or lower."
That brings me to my question: Is a subwoofer with a passive radiator more like vented, or more like sealed?
