AVS › AVS Forum › Audio › DIY Speakers and Subs › Quad RSS390HF-15 Build (in progress)
Quad RSS390HF-15 Build (in progress) - Page 2
post #31 of 50
Saturday I completed one and on Sunday, completed another. DONE!
Whats left is the roundover, bondo, primer, and paint. For my first build it came out better than I expected. There are some gaps and one does not sit level but its nothing a little bondo and adjustable spikes can't fix biggrin.gif
I think I'll connect all four to my computer to have a listen for a few hours tomorrow.
post #32 of 50
Very nice, can't wait to hear your impressions and see your measurements!
JSS
post #33 of 50
I can't remove the drivers from the enclosures... I tried making a hook from a small screw driver and it still won't budge.
I may be able to push a stick through the terminal plate and push the magnet. Would like any other ideas but for now...go to go to work mad.gif This is going to bug me all day!
Edit: Phew! I was able to get it out, used a stick to push up on the basket through the terminal plate.
Edited by Mrkazador - 6/27/12 at 12:30pm
post #34 of 50
I have a question about the speaker gasket...do you stick it to the driver or enclosure? The driver already has a thin gasket, I assume I take that off and put on the new one I bought from parts express.
post #35 of 50
I stuck gasket tape to the enclosure.
post #36 of 50
No, do not take the gasket tape off of the driver - LEAVE that on there.
The gasket tape that you purchased from PE needs to be applied to the box itself, where the driver will sit.
post #37 of 50
I'm 99.9999% complete with the boxes, I updated my post with some pictures. This saturday I will have them up and running, hopefully with some graphs. biggrin.gif
post #38 of 50
Looking forward to graphs. I got some absurdly flat response on my quad build. I'm still questioning if it's reality. Hope you have similar results.
post #39 of 50
Its been a couple months since I've updated anything. I did run some graphs and I got some pretty nasty dips at 35hz and 80hz IIRC. I tried spinning some of the subs around and it did nothing, not much I can do with placement but Audyssey does flatten it out some. I couldn't be any happier with the sound, when pushed hard it sounds clean. Right now I'm using some old HTIB speakers sitting on top of the subs. I plan to build 3 seos12 speakers in the future.
I did create some videos if anyone cares...
The receiver volume was set to -5 but the subs were running hot, my guess would be +6db. Radioshack meter dial is at 110db. I probably could have gone a bit further but I was too chicken tongue.gif It sounds distorted because the microphone was not designed for such high spl.
Jurassic Park 3
Jurassic Park 1
WOTW
Kung Fu Panda
post #40 of 50
Nice! How about some final product pics...I'd like to see how those grills are mounted and look. Thansk!
post #41 of 50
I'll get more pictures when I have some free time.
post #42 of 50
Uh......... Get any free time yet lol??? I want to see these
post #43 of 50
Forgot about that lol. Let's see if I can remember this time and get some pictures tomorrow.
post #44 of 50
The cloth is not jet black so it does kind of look a little tiny bit purple. Its really not that bad in person in normal lighting conditions.
Here is the clamp. I added a piece of USB cable to fill in the gap and the grip is pretty good, no play at all. The clamps were made for woofers that are mounted on top of the baffle, thats why there is a gap. I plan to replace these with some Angled Clamps, I think these will look nicer.
This is what the setup currently looks like. I plan to build 3 slim sealed SEOS Tempest. I was thinking of placing the left and right Tempests in the the corners but I don't know where to put the lamps without it looking weird.
post #45 of 50
Nice. Where's the other two?
post #46 of 50
Under the lamps.
post #47 of 50
Hi, I started yesterday a thread about finding good void free but also formaldehyde free plywood. PureBond satisfies the latter but I was wondering about your experience about the void-free part. Is it dense enough, and did you notice any voids while you were cutting? I am thinking of the maple variety (shipped only) as I would like to finish it, not paint it. Would you say it is finish quality?
thanks
post #48 of 50
There wasn't a lot voids in it but I wouldn't use it again because of the thin veneer on the outside. The veneer is pretty nice but its useless in a cabinet if you only plan to use glue and no screws.
post #49 of 50
Thanks. It seems that going for Baltic Birch or cabinet grade ply might be a solution for me.
However, I do not understand why a nice veneer is useless with glue..
post #50 of 50
Its a very thin veneer and I would think the veneer would separate from the plys if its only held by glue.
