I'm sure this has been discussed before but I can't find any info regarding my particular setup. I'm going to have 4 zones (front lights, star ceiling and rope lighting, floor lights for steps, and the rest of the room). I really don't care to have many different scenes in my theater. Just the basics will do.... entrance/intermission, full on, full off, gaming/entertaining, and movie mode. Will the spacer system suffice?
Ohh btw, this will all be controlled via a Harmony One.
Also, I plan to put the switches next to the door as you enter which will be on the left side wall about 4 feet from the screen wall. I'm assuming that if I point my remote at the screen to control all of the AV equipment it will NOT hit the dimmer switches? If this is the case, is there a way to use an IR repeater on the spacer system?
