Originally Posted by BllDo
Ha, that's what you get for thinking you might actually "finish" your theater.
The ceiling panel doesn't have to be huge. The first idea is to absorb some of the reflections from the speakers. If you draw out your space from a side view, you can try to calculate the midway points on the ceiling between the speakers and the seating positions. This is the old mirror trick, but without trying to get someone to hold the mirror on the ceiling while you move from seat to seat.
The second idea is to absorb some glare, this one is simple. Turn on a movie and take a look to see where the light is reflecting.
Just as a completely baseless guess, I might think about two panels maybe 75% of your room width by 2' across placed at the first reflection points would go a long way.
Right, I know.... I should just go an smash my face against a tree...
Thanks for the ideas on the ceiling panel. I bounce it around in my head for a bit.... Thinking I may need to use some sort of fiberboard to mount the fabric to in order to keep it from sagging. A bit of spray adhesive and some sort of thin, rigid sound deading material. Kinda like a headliner in a car.
