Thanks Bud! Kinda "under the gun" lost a couple of days last week and got off pace for my flooring install on Wednesday. As long as the drywall is done and the ceiling is painted, I'll be fine. IF I can get the 1st coat of primer on the new wall I'd feel better, just not a big fan of painting walls over new carpet if it can be avoided.
AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › KnoxVegas "Bang for the Buck" Theater
Featured Stories
KnoxVegas "Bang for the Buck" Theater - Page 2
AVS Top Picks
post #32 of 164
9/3/12 at 8:22pm
- Shan
- Trader Feedback: 0
- offline
- 565 Posts. Joined 8/2003
- Select All Posts By This User
- Johnny14o
- Generally confused...
- offline
- 136 Posts. Joined 1/2008
Thanks Shan. It is a definite upgrade, but the irony is...it's one that no one will ever see! LOL! Oh well, if it means I can turn it up to "disturbing" on the 'ole Onkyo without waking anyone up... IT'LL BE WORTH IT!
- Johnny14o
- offline
Me...tired...can't ...go...on....
Ok, been crankin on this thing for 5 straight days now... starting to make me sore!... Blah, Blah (violin plays in the background...)
Wet sanded walls and wiped them down. Got 2 more tubes of acoustical sealant and applied it to the perimeter, still have some for the receptacles. Moved everything out of the room making ready for carpet tomorrow1
Got 3rd and FINAL coat of paint on ceiling, that sucker is BLACK..
Did have 1 casualty of war, while moving the couch, loveseat, and riser... hooked a foot of the love seat on the corner of the doorway. Bit of missing drywall. No biggie, it's going to be covered by trim. Just gonna add in a small piece and do a little touch-up
Made my own DIY room filter... works good! Catches the drywall dust!
Picked up some Primer today and had it tinted. Figure having it tinted will help me cut down on my subsequent coats.
TOMORRW,, Carpet and hardwood!
post #35 of 164
9/4/12 at 11:12pm
- GIK Acoustics
- Bringing Your Sound to Life
- offline
- 191 Posts. Joined 9/2012
Looks great! The front wall construction idea pictures looked good earlier - gave you much thicker absorption at the front end which will be great for trapping bass. One thing I will say is that you may want to be prepared - building walls with a higher STC rating will likely cause some low frequency issues that weren't imminent prior to construction. A higher STC means more sound stays in the room, meaning low frequencies that once were transmitted out of the room before, now aren't. You may want to consider some thicker panels around the room.
- Johnny14o
- offline
Thank you for the feedback. Actually your timing could not have been better. Moving everything out last night, I took a picture of the underside of the riser.
Would stuffing it full of insulation help with the low frequency issue you mentioned? Or is there something BETTER to use in this situation?
post #37 of 164
9/5/12 at 7:55am
- Ted White
- 14 Year Member
- offline
- 8,122 Posts. Joined 5/1999
- Johnny14o
- offline
Would it be fair to assume that the QuietGlue Pro / Green Glue in between the double layer drywall act as a LFE absorber?
I would think that with my PREVIOUS wall (Single 1/2" Drywall, no insulation, no decoupled studs) would almost act as a resonance chamber for sounds. From what I read the resonance of certain frequencies within a wall can actually AMPLIFY the amount of sound being transmitted, and in some cases BACK into the room or origin.
Sooooo.... (think I already know the answer) would it be beneficial to install the insulation inside of the riser? (I guess I see the riser as a resonance chamber WITHIN the room)
Second question... Would installing insulation to the riser double as a bass trap?
- Johnny14o
- offline
Door question...
Moving into the next "phase" of the project. I am replacing the original, hollow door and frame. I am building a custom door frame to accommodate the extra thickness of the wall, and to support a solid, heavier door.
My question. What kind of door (material) is everyone using. Example: Solid wood interior or solid wood exterior (a bit thicker than interior doors). Pine, oak, etc.
Or should I look into a HEAVY solid door that is not solid wood, rather it is basically particle wood.
I am also planning on covering the door (to the inside) with Mass Loaded Vinyl and same exterior carpeting that I am mounting to the walls. The door will also have an automatic gasket on the bottom and gaskets around the sides and top.
post #40 of 164
9/5/12 at 11:03am
- Ted White
- 14 Year Member
- offline
post #41 of 164
9/5/12 at 11:20am
- aaustin
- Young HT Builder
- offline
- 1,225 Posts. Joined 12/2010
post #42 of 164
9/5/12 at 3:43pm
- GIK Acoustics
- offline
Yes, stuffing the riser should help in both those ways. You will prevent any inherent resonance the riser may introduce (which would act as a panel absorber of sorts - definitely welcomed) and it should help to alleviate some low frequency build-up in the room. You may end up needing additional bass trapping (perhaps in corners in the room, or on the wall), but it is hard to know without being able to test the room (or even have an account of how it sounds, since construction isn't finished yet)
Soundproofing removes leaks of sound that travel through flanking paths - walls, floors, HVAC, etc. When these sounds 'leak' outside of the room, they are being transmitted out of the room. When you reduce these flanking paths, those sounds do not travel outside of the room anymore, which can cause frequency buildups, usually evident in low frequencies inside the room. As an example, a concrete bunker is wonderful for isolation - but awful for acoustics.
Somewhat...if you research "Constrained Layer Dampening" you can see how it works. Pretty simple really, as sound vibrates the drywall, the drywall flexes in motion (of course, very little). The Green Glue will take those vibrations, and convert the energy into heat (similar to porous absorbers), and thus gives us a higher STC rating.
- Johnny14o
- offline
Thanks for the feedback on the door Ted and aaustin. This helps me plan out the next steps..... Step 1... look for a door!
Need to consider depth of the door inside the frame. With 5/8" - 3/4" MDF on it would it stick out too far?
If it is OK a thought is to cut the MDF slightly wider than the actual door slab and utilize a dual gasket system. One set of gaskets around the outer strike and one between the MDF and trim. Maybe overkill, but it should seal it up TIGHT. Now that there is hardwood(instead of carpet) in the hallway outside the Theater door, I REALLY need to keep it sealed up!
WOW GIK, great information. I will definitely keep it in the front of my mind as I move forward with the project.
- Consider the riser "Stuffed"
- Any voids I have in the false wall I will frame it up for the rest of the ROXUL I have.
- When everything is back up and running I will locate other places in the room for additional bass traps. One BIG concern is the back of the room, behind the riser.
The room meets the roof, thus has a taper to it. With this angle I can see it being somewhat of a "funnel" and focus a lot of sound waves into a pool of sound. I will have a cabinet (counter height) to the left and right with a built in desk top in the middle between them. I will definitely be reaching out to the forum for ideas on practical bass traps for this area.
post #44 of 164
9/5/12 at 5:26pm
- aaustin
- Young HT Builder
- offline
Exactly, so sound energy is changed to heat energy which therefore results in less sound being heard outside of the room. So soundproofing does not keep more sound in the room, it changes the sound that would normally leave into something that cannot be heard. Instead of sound leaving the room, more heat does.
I don't see how soundproofing results in more sound staying in the room.
I'm not trying to be confrontational by the way, just curious.
By the way Johnny, regarding your riser and insulation, I would do some more research about cutting vents into it to allow it to act as a bass trap. I've seen this done successfully in many builds, but I know that it takes some thought and calculations to get it "tuned" correctly.
post #45 of 164
9/5/12 at 5:52pm
- GIK Acoustics
- offline
That is only in constrained layer dampening and in the case of added insulation between the studs, but we know those are not the only pieces of the isolation system. These are small additions to the actual STC rating as a whole. Most of inherent isolation comes from mass, mass, and more mass. And the point is, low frequencies can penetrate thin partitions (thin in terms of low frequency waves) - but have a hard time penetrating hard, dense, heavy, thick material. I keep referring to concrete because its easy to imagine, but other materials can act similarly too. I remember Rod Gervais commenting on this previously with a good quote. I thought it may have been in his book, but I did a quick look through and couldn't find it. Perhaps he said it on another forum? Either way, I'll do some more digging and let you know if I do find it.
I suppose I should have been more specific: not every step of isolation will encourage sounds to stay in the room, but the main step of isolation - that is - mass, mass, mass...does encourage sound staying inside the room. Also in isolation, you try to remove any diffraction that could occur through vents, door frames, and other openings. When you create an air tight system, diffraction is not possible. Lastly, dampening flanking paths won't encourage any more sound to be inside the room than previously, but removing them could.
And I didn't find your posts to be unusually provocative - we all strive to learn - there is no problem there. I question other ideas similarly when I'm not sure.
Anywhoo, no point to dirty up this thread anymore with this. I'd be happy to chat with any of you over PM, perhaps we could find some cool links to share and learn more. I'm personally not an isolation expert - most of my knowledge when it comes to this is from books.
Of course! Those points you make above are all good for covering - its good you are able to make for some other functional use out of that riser. The space in the back does seem like it could contribute some problems, but it will be hard to know without listening. It is a great spot for trapping though - out of the way visually, and we tend to see lots of bass build ups in the back of the room.
I will keep an eye on the thread and pop in again when necessary. Good work so far - keep up the great build!
Edited by GIK Acoustics - 9/5/12 at 6:10pm
- Johnny14o
- offline
Aaustin... You lost me at "thought"... LOL!
I'll go ahead and stuff it, thinking it will cut down on it resonating. I know when it gets walked on, it sounds like you would expect... Like hitting an empty wood box. That CAN'T be good for the "big picture".
I'll do some research on what it would take to tune a bass trap... If it is as easy as a dozen holes cut with a hole saw.... I'm in. You wouldn't happen to know a link or another build where I can get more info do you?
Oh on a side note... The same carpet you got (different color) gets installed tomorrow. They couldn't get to it today, the hallway had an 7ft section that was up to. 1in low. Sad thing is, it was not a settling thing, it was crazy construction to start!
post #47 of 164
9/5/12 at 7:09pm
- aaustin
- Young HT Builder
- offline
GIK, thanks for clearing that up. I understand your point now. It's always a good day when you learn something new!
Johnny,
I'm no expert when it comes to these types of things, but this thread has some good info.
http://www.avsforum.com/t/1103345/fixing-my-riser-broadband-bass-trap-and-from-56-to-7-deep#post_15441346
I know that properly built riser bass traps are something that Dennis Erskine and his design team incorporate into many theaters.
Congratulations on the carpet! I love mine and am looking forward to some pictures.
Johnny,
post #48 of 164
9/5/12 at 8:14pm
- Ted White
- 14 Year Member
- offline
In 2006-2007 we ran various tests as time allowed at Orfield Labs in Minneapolis. We found that if a wall had a resonance frequency of 100Hz (just an example), then frequencies on or about 100Hz were most readily removed from the room. Partitions at resonance are like superconductors and allow the resonance frequency to pass much more easily. This is at the heart of why we look to build structures with as low a fundamental resonance as possible.
- Johnny14o
- offline
Luck comes in spurts... Chaos brings friends!
Crazy week with the wife out of town on business and me being "Mr. Mom", late night drywall, late night painting, and coordinating with contractors.... Oh yeah, and WORK...LOL!
Thank you to EVERYONE who has provided feedback and input thus far. You MAY not know it, buy you are DIRECTLY impacting this projects end result.
Here is the end of this phase (milestone, really)
Hallway hardwood was delayed (and pushed everything back 1 day) because upon removing the carpet, was discovered the hallway was as low as 1" over a 9' run...
The flooring guy and I came up with a combination of a 3/4" piece of plywood over a 6' section in the middle. Then cut 1/4" thick pieces of plywood and built up the thickness starting with 3" then 5" then 12" -16" wide, feather the wood out to meet the bow in the floor. This way it minimized the amount of leveler that had to be used.
Ceiling painted...... Check
Walls painted......Check
Carpet installed......Check
Hardwood in hallway installed.........Check
I have enough hardwood strips left over, I am going to do hardwood (myself) in the equipment closet. (When I get brave!)
I'm exhausted... gonna take a break next week...
When I get back on it, I plan on:
- Getting the ceiling can lights painted and re-installed
- begin re-installing cabinets and making custom desktop between cabinets, cutdown and re-install countertops
- Cut ports/vents in riser and stuff with insulation ("pink stuff" or ROXUL) INPUT? (Remember I already have some ROXUL, so it is not a matter of cost. Just a matter of IS one truly better than the other?)
- Paint and install baseboard in hallway and Theater
- Get solid core door and install door frame and new door
- Johnny14o
- offline
Fabric wall questions/design ideas...!
I am moving into the next phase of the remodel. Once I get cranking', hopefully everything will move quickly. Thus, I am looking for suggestions.
I am considering a "mixed bag" of fabric covered panels along with wall carpet to make up the wall between the False wall to the front and hallway door / window on the side.
Probably carpet from the baseboard to about 2' then fabric panels to the crown.
First question, has anyone had any experience with Fab-Trax or Fabricmate track systems?
Pricing appears to be similar so it will come down to ease of installation.
Second question is what to use inside the track frame. Considering Linacoustic RC material, but having a difficult time locating a source, without it being shipped.
post #51 of 164
9/18/12 at 12:09pm
- Dradius
- offline
- 453 Posts. Joined 4/2007
- Johnny14o
- offline
Me too. Only I will have to admit, I am not entirely sure what I will be listening to/for when it is up and running. Or how to "tune" it. I am just trying to follow as many of the basic guidelines of "good home theater-ing" as possible.
Admittedly, starting this project my main focus was the soundproofing of the common wall to rest of the upstairs. Now I am wrestling with the additional concepts of making it sound "good"... I'm lost in a ocean of theory and contemplation.....
Anyone have input on concepts/principles of how to tune in a theater?
I will be posting some pics of the "conceptual" wall panels soon (just as soon a I draw them...
)So far all I have is the riser...
putting vents in the front and the back. Porting some of the chambers . Then filling full of insulation and then cover the bottom with material to "keep in the pink stuff". Input anyone? I left the chambers separated down the middle (the front from the back), is there any benefit to adding additional ports through the middle section? Allow the front chambers to "flow" into the back?
Edited by Johnny14o - 9/19/12 at 10:03pm
post #53 of 164
9/19/12 at 9:43pm
- GIK Acoustics
- offline
Hey Johnny,
You can use Room EQ Wizard to test your room if you have a microphone handy. Here's a video we did explaining how to download, install, run, set up, and test with REW: http://www.gikacoustics.com/video_rew_room_eq_wizard_tutorial.html
An omnidirectional microphone would be best for showing accurate graphs, but it is not really necessary. Other mics might paint a prettier picture, but you can still see large resonances, nulls, and peaks regardless of the microphones you use.
You can run multiple tests for - if you wish - all the different seating positions. Or perhaps just the middle seat in each row. The graphs will show room resonances (modes), any cancellations that might be happening (nulls), standing waves, flutter echo, comb filtering...etc. When you know the problem frequencies of the room, a lot of the guesswork is taken out of how to treat and where to treat.
Let me know if you have any other questions!
- Johnny14o
- offline
Hey Johnny,
Hey Johnny,
SWEEEEEET!!!! Wow thanks! ....................20 min later..................Holy crap! My head hurts! LOL I just watched the tutorial on the software and red the Case Study examples. Also, brushed up on the diffuser section. Man that a lot of information... GOOD information.
Based on some of the concepts, I can see a problem area in my room (See top of page 1 of my thread). It will be the back of the room where it meets the roof. This will be a bit of a funnel for sound and I have cabinets going into that area or it would be a great spot for bass traps.
Alex, would you recommend diffusers or sound panels on the angled ceiling portion (where it hits the roof)?
post #55 of 164
9/19/12 at 11:21pm
- GIK Acoustics
- offline
Diffusers are wonderful but a little tricky to place. I would worry about getting the absorption in there first, with the diffusion as an after thought. It also depends on how far your rear speakers are from the back wall area. If it is within a couple feet, I wouldn't recommend diffusers. But if you're a good 5-6 foot away they could certainly be useful. Perhaps both diffusion and absorption could be beneficial here.
It really depends - if that area has a large boom to it - it would be a really great place for absorption. Considering too, that the wall is angled downwards it will throw a lot of reflections right back at listening position, so I would certainly add some sort of treatment there. Diffusion doesn't do much below ~600 Hz (depending on size of the diffuser) so, I would worry first about getting the bass in check and then adding diffusion later if it is wanted.
post #56 of 164
9/20/12 at 9:48am
- NickTheGreat
- Aspiring HT Guy
- offline
- 807 Posts. Joined 1/2012
- Johnny14o
- offline
LOL! Spacecraft cabinet!
One of my previous lessons (from an earlier riser) was that in my "modular" setup (as in not permanent) was to use 1" x 6", 8" etc instead of 2" x 6", 8" etc. Significantly lighter and mobile. I had my next door neighbor help me move this one and it was no big deal, just bulky. Maybe I should add wheels...
......Anyway, had a slight delay today getting materials this morning before work.
Stopped off at a neat place here in Knoxville, TN called Knox Rail Salvage to pick up a solid, 6 panel door. This one is even fire rated and DENSE! Only $25.00!!!
But while I was in hunting it in the racks.....BAM!!! A guy failed to put his parking brake on and it rolled into my FLEX....
To help illustrate, my car WAS squarely parked in between the yellow lines...... (Please ignore all the work junk in the back of the car, it got thrown around too)
So after 5 hours of reporting it to my company, waiting on the wrecker, getting the rental car, and unloading all my "junk" from the FLEX to the rental.... kinda killed my motivation for the day.
post #58 of 164
9/20/12 at 2:11pm
- NickTheGreat
- Aspiring HT Guy
- offline
post #59 of 164
9/20/12 at 3:19pm
- Mr.Tim
- Code Guy
- offline
- 1,661 Posts. Joined 7/2004
- Johnny14o
- offline
Back to Forum: Dedicated Theater Design & Construction
- KnoxVegas "Bang for the Buck" Theater
AVS Top Picks
Currently, there are 1124 Active Users
(179 Members and 945 Guests)
Recent Discussions
- › *The Official Samsung PNxxC8000 Owner's Discussion Thread!! 2 minutes ago
- › F8500 Recommended Settings Thread..... 2 minutes ago
- › SVS Dual SB12 VS PB12-Plus 3 minutes ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 3 minutes ago
- › Hot Off The Press: The Latest TV News and Information 4 minutes ago
- › Tekton Pendragon 5 minutes ago
- › 3D is Not Dead... 5 minutes ago
- › Microsoft fires the first shot in the "NEXT" generation.... 7 minutes ago
- › Epson 5020UB Owners Thread... 8 minutes ago
- › Is RG6 Coax the same as "Digital Coax" 8 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
