I have recently purchased a brand new AV7701 to go with my MM8077. About a week after I had installed it, I realized that the right surround tweeter is making an intermittent static noise, as if it is picking up interference. So, I decided to perform the following tests:
• I swapped the speaker cable between the left and right surround speakers: the noise remains
• I moved the right surround speaker from its original position to another a few meters away: the noise remains
• I swapped the XLR outputs of the AV7701 between the left and right surround channels, while keeping the same inputs on MM8077 (effectively swapping the rear channels): the noise moved from the right channel to the left
• I used RCA unbalanced inputs instead of XLR: the noise remains
• I moved the XLR output connector on the AV7701 from the right surround position to the right surround back position: I could still pick up a static noise. In fact there is a much weaker version of the same noise on the front right speaker, as well. Both front left and surround left speakers have no such noise.
In addition to the static noise from the right speakers, coming out of the tweeters, there is a constant low-volume buzz coming from all 5 woofers. However, I think that this one is normal.
My speakers are B&W Theatre (685,686). I have already run Audyssey calibration and I have updated the processor to the latest firmware.
Do people have any ideas as to what may be going on?
Aris.
Aris.
So, it seems that it is a grounding issue. Well, …
