So I'm looking at picking up a used Nuvo Concerto system from a friend but I can't seem to figure out how to configure the system. Is there a way to obtain the configurator software from Nuvo or would I have to purchase it somewhere? I see a package for sale from Smarthome for $500 but that is more targeted at a technician who is going to sell their services, I am just looking to configure it for my home use. I sent an email to Nuvo support asking them but I figured maybe others here had been successful?
Also the Nuvo system I'm looking at comes with the NV-18DDSP keypads. Is it possible for me to use some of the newer keypads with the concerto system? Or how about the iPhone app interface? On their website they list these as accessories for the concerto but I wasn't sure if there were certain versions that they worked with.
Also I'm curious about firmware/software updates as well, are their any and how would I access the updates?
I am looking for a cheap way to enable my pre-wired home with whole-home audio. I have plans to do a more complete a/v distribution later on but the first step is a whole home audio. I haven't thought through everything yet but I am thinking about using an Airport Express to feed iTunes audio into the system...unfortunately I would have to use the remote app and I would loose control with keypads...still figuring everything out
Thanks in advance!
Justin
Oh and the unit I'm thinking of purchasing is the NV-I8DM, I see now that the one of their website is I8GM so I suspect there is a significant difference between the two...
Thanks in advance!
Justin
