hi huys,
i am new here and my knowledge in Pj is quiet limited so i copme to to get some advice...
i wanna set up a home theater in a two section living room, i can separate the section with a curtain and do the set up in the smallest section.
i wanna use it for movies mostly, as well for sport, during the day the curtain between the 2 sections may be open and just close the blinds in the large section of the living room. so i dont know about the brightness ?
i wanna use the PJ on a white wall, i dont want buy a screen, i wanna set up the PJ on the ceiling of the room.
and finally i need something budget-wise not too expensive (max 600$ or 700$) with a good life expectancy for the bulb
i would appreciate any comments and advice ...
tks
che
tks
che
