HDMI issue
post #1 of 5
I am using a computer with a ceton 4 tuner card with AMD Radeon HD 6500 Series video card. I am not getting sound using the HDMI port. I get sound through the HDMI port from my laptop.
How can I get the sound to go through the HDMI port? Thanks.
post #2 of 5
If it is Windows 7, did you select the appropriate HDMI port in the Device Manager -> Sound section? Also some cards require that the HDMI port audio be enabled with the card's drivers.
post #3 of 5
Yes it's WIndows 7
There are two options in the sound section
AMD High Definition Audio Device
VIA High Definition Audio
When I go to properties the only options are to: Driver Details/update Driver/Roll Back Driver/Disable/Uninstall
Edited by Gmojo - 6/6/12 at 12:04pm
post #4 of 5
Yes it's WIndows 7
What happens when you select the AMD option or the VIA option? Any differences?
post #5 of 5
OK It's working now, thanks.
