Hello,
I have recently installed in an EPSON EH-TW9000 3D projector (European model equivalent to EPSON 6010).
I have connected the projector with my HTPC. The HTPC has installed Windows 7 32bit, an i5 CPU, 4GB or RAM, 120GB SSD and an AMD HD6850 GPU.
I am using Blu-Ray isos that are stored on my unraid server. The software I use for playback is Total Media Theater 5 (latest release - 120). I have enabled the automatic refresh change in TMT in order to change the refresh reate to 24hz for Blu-Ray 3D playback. I have also enabled the AMD HD3D in the 3D settings of TMT5.
When I try to play the following 3D isos in WMC7 the iso mounts but after a while I am returned to the start screen of TMT5 that shows the disks. If I try to play them with the external player, TMT crashes. In 2D mode they play without problems.
The strange thing is that I can playback Cars 2 and Kung Fu Panda in 3D.
I forgot to mention that I am using CCC 12.4.
Do you have any suggestions as to how to solve this problems ?
Thanks a lot.
- Avatar
- Ghost Rider 2
- John Carter
Thanks a lot.
