AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Direct links to posts
post #1 of 3
I used to be able to include page# and post# in the AVS URL and go directly to that post. This no longer works. Is there a way to enter your URL and go directly to a post?
post #2 of 3
Hi DB100!
My name is Cristina, I'm part of the Huddler / AVS Team.
To find the post permalink, click on the post number in the upper right corner of the post (i.e. "post #1"). This itself is the link to the post specifically and will load the post at the top of the page.
126
For example...http://www.avsforum.com/t/1413935/direct-links-to-posts#post_22102157
Let me know if that answers your question!
(I also went ahead and moved your question to a new thread to allow other folks to more easily find the answer too.)
post #3 of 3
It looks like the new Forum software uses "absolute" post numbers in its URLs instead of a number relative to the current thread.
The post number at the upper right of each post is a link (URL) to that post. In Firefox, if you hover the cursor over that link, you can see its URL. An awkward way to obtain the URL of a particular post is to select that link (perhaps opening it in a new tab or window). That URL is then shown in the URL address field of your browser. Then you can use your computer's copy option (usually available by clicking the right mouse button) to copy its URL to the clipboard, You can then paste the URL wherever you need it.
  Back to Forum: Forum Operations Center
