going to set up my system soon but when i caliberate it using the denon audyess. Do i do it with both subs connected with a y-
splitter because i'am going to run a dual sub system.
Or do i do it with only 1 sub connected and when its complete do i add the second sub later?
I'am assuming that i should leave the knob in the middle.
Any help will be appreciated as, thanks in advance.
Does the EQ process use different test tones versus manually... any clue which would be more accurate for all frequencies...
