Chriscpm;
Ok, now I know what you are talking about. It wasn't clear exactly what you were recording. On a main 'HD' channel, a 4x3 program plays back normally since the the entire picture area is accounted for (not sure what the correct technical term is). On sub-channels (usually SD), that isn't the case. For whatever reason the recording/playback process 'stretches' the image horizontally.
I forgot about this quirk. If you choose 4x3 in the aspect choices, does that solve the problem? How about if you transfer that to a PC, how does that playback?
eastavin;
You have a PM. WBBZ & WPXJ and WNYB (if you watch that) should have the same issue with their sub-channels
Edited by videobruce - 2/10/13 at 6:26am
eastavin;
Guess we'll find out around Oct. 2014
