AVS › AVS Forum › HDTV › HDTV Recorders › ePVision PHD-VRX Owners Thread
ePVision PHD-VRX Owners Thread - Page 6
post #151 of 1561
I'm getting an education concerning cable. Right now I'm in the mountains of western North Carolina and my antenna only gets 2 PBS channels, so I'm playing with cable. I have an old TVIX 3310 that only has one tuner, but it can work with the cable feed. I definitely need something better like the PHD. I'm still working my way thru programming recorded in Florida off my antenna. Those recordings are stunning compared to cable. But then they are 5gbytes each as opposed to the 1gbyte cable recordings.
post #152 of 1561
When this device is recording, it displays "rEC-1" or "rEC-2". Why not "Rec-1" or "Rec-2"?
post #153 of 1561
Caps Lock was on during the programming. [joke]
post #154 of 1561
At the start of this thread, the author made a brief comparison between this device and a Tivo. I'd be much more interested in a comparison in the same price range. How would it stack up against the PalDVR, CM7000, or CM7400?
post #155 of 1561
DB100,
Because on this display, "Rec-1" would show up as "Aoc-1". There's only so much you can do with 7 segments.
post #156 of 1561
Originally Posted by VideoGrabber View Post
...There's only so much you can do with 7 segments.
Aaaaaah. I get it. That's funny. I never even thought about the limitations of those 7 segments (88888). Never mind....
post #157 of 1561
Just got mine on Friday; OTA antenna tuner is very good, and pic quality also good with tweaking. Remote is slow to change channels and use Channel Up-Down buttons. The Channel Master remotes were better on both models. Will probably get a Logitech universal remote. Haven't yet connected to cable or tested DVR features. But for OTA antenna, both the CM7000 and the VRX have more reliable tuners than the 7400 for antenna reception. For some reason, the 7400 tuner is problematic.
post #158 of 1561
Yeah, but I betcha they got a really good deal on these surplus digital clock readouts . . . biggrin.gif
post #159 of 1561
Originally Posted by tylerSC View Post
Just got mine on Friday; OTA antenna tuner is very good, and pic quality also good with tweaking. Remote is slow to change channels and use Channel Up-Down buttons. The Channel Master remotes were better on both models. Haven't yet connected to cable or tested DVR features. But for OTA antenna, both the CM7000 and the VRX have more reliable tuners than the 7400 for antenna reception.
Thanks for the info.
I've been using my PalDVR (CM7000?) for years now...well worth what I paid for it. I'm interested in this device because of what it can do that the PalDVR cannot do. It can do cable and, in theory at least, it's recordings can be moved to a PC for archiving. So, I hope the quality is comparable to the PalDVR.
post #160 of 1561
OTA antenna reception in western NC can be problematic due to the mountainous terrain. However, if you are on the right side of the mountain near Asheville, some folks can receive a good signal from Asheville, Greenville-Spartanburg, and even Charlotte. A good, high gain HiVHF/UHF antenna and possible 269 preamp for AVL/GSP, and a good high gain uhf antenna and preamp for Charlotte, such as 91XG or CM4228. I am in GVL SC and get good reception of AVL/GSP and Charlotte channels.
post #161 of 1561
I only mentioned TiVo simply because it is usually regarded as the "premier" consumer purchasable DVR in spite of the numerous reasons I don't like them.
The PalDVR & the CM700 is the same thing, only with different names with a flaky Rovi supplied TVGuide like Guide that is hit or miss depending on your market.
The current CM7400 is a couple of steps above this mostly due to it having a internal HDD, optional working paid Guide available, internal wireless hardware & a few other amenities. At the current $230- $30 coupon (or was it $20) plus a HDD and a USB wireless stick and you are around $350.
354
Edited by videobruce - 6/17/12 at 4:38am
post #162 of 1561
It's not the remote, it's the design of the DVR. Considering it isn't normally "timeshifting", channel change is slower than it should be, especially when in the Guise waiting for data to load on each station change.
As in reception or for some other reason(s)? Or is it a thermal issue that that is well known for?
With the right program & drivers, Windows can access a ext2 partition so there shouldn't be any need for the 'two HDD's per post #5. I haven't explored further since I sent my test unit back to see what/where the problem with their internal formatting utility that never worked on either drive I tried. mad.gif
Edited by videobruce - 6/17/12 at 4:46am
post #163 of 1561
They are using a 7 segment LED display, not a lot of choices on how to make characters since they are intended for numerals only.
post #164 of 1561
Originally Posted by videobruce View Post
No "theory", it's been already done. With the right program & drivers, Windows can access a ext2 partition so there shouldn't be any need for the 'two HDD's per post #5.
I used the words "in theory" because I thought someone had posted that VLC could not play an .mpg file recorded by this device? Has anyone actually loaded a recording into VideoReDo?
post #165 of 1561
I noticed there is a firmware update: firmware (version VRX.242.18.10) -
My question is, how do you know what firmware version you have? Is there a selection on the machine where you can check?
Overall I am satisfied with unit though the slowness of the remote is frustrating and the fact that checking the guide means changing channels. I also noticed that after decades of cable with the usual male trait of having a remote in my hand and checking other channels very two minutes means that I now want to push a button of some kind all the time! LOL
post #166 of 1561
Same here. I'm satisfied with the unit, too. I thought I wouldn't be (after reading this thread), but after "playing" with the unit for a few days, I can honestly say that I like it. I actually canceled my cable service just a few hours ago. I kept the internet, but canceled the cable. I'll be saving $85 a month.
post #167 of 1561
What is the "Net" feature for? Every time I press the button it takes me to Youtube.
post #168 of 1561
You asked and answered your own question. biggrin.gif ePVision hasn't added support for any other online video services yet.
post #169 of 1561
Yes I did (answer my own question). Lol. I only asked because I wasn't sure. I kept asking myself "Why is this thing taking me to Youtube?" I didn't know this unit supports Youtube.I have a Magnavox streaming device sitting alongside the VRX. It's like the Roku, except it has a Youtube channel. I noticed that whenever I'm using the VRX's remote, it will TURN ON the Magnavox player (I have to keep turning it OFF). Since the Magnavox has the Youtube channel and the VRX's remote keeps TURNING ON the Magnavox, I actually thought the VRX was turning on the Magnavox and then starting up the Youtube channel, somehow. But, that didn't make sense because the Magnavox isn't "even connected" to the VRX. I have to keep reminding myself NOT to point the VRX's remote towards the Magnavox.. No matter what I'm using it for (changing the channel, turning the volume up/down, scheduling a recording), if i have it pointing towards the Magnavox, it will turn it on.
post #170 of 1561
Mmmmm. I'm seeing mostly positive reviews. Interesting.
post #171 of 1561
How is the quality of the video compared to going directly into a TV? The only reason I want to get one is for watching football at higher quality than my directv as well as pausing, rewinding, etc. How does it compare to plugging straight into the tv?
post #172 of 1561
See post #10
MannyNY; Apparently you haven't read the first 10 posts. Your questions are answered there.
post #173 of 1561
Someone that never had any experience with a DVR wouldn't be expecting anything more. It's like getting your first car, even if it was a Vega. wink.gif
post #174 of 1561
See post #10
And I guess you didn't read the name of the user you were quoting, apparently. I didn't ask that question.
post #175 of 1561
The quote addressed one post, the response to your post 167 address that. Two separate responses!
post #176 of 1561
I've owned and own a few DVRs. The VRX doesn't even come CLOSE to being as good of a DVR as the ones I've owned/own. That said, I'm still satisfied with my purchase.
post #177 of 1561
A DVR is like a box of chocolates..........
post #178 of 1561
Is it possible to manually schedule a recording at the same time of day and day-of-week every week (e.g. record at 7:00 PM on Thursdays on channel 6.1)? This is such a basic scheduling task, but this unit doesn't appear to have it.
post #179 of 1561
From reading the scheduling pdf, it seems you are right. No "weekly" option. That is not logical. Half of my recording is "weekly".
http://www.epvision.com/HDTVSTB/Documents/PHD-VRX_Recording_Features_Guide.pdf
post #180 of 1561
Joe, it looks like you found another 'glitch' that I missed.
I've updated post #6 to include page three of the Recording features guide;
665
Edited by videobruce - 6/18/12 at 8:15am
  Back to Forum: HDTV Recorders
