AVS › AVS Forum › AVS Forum Information › Forum Operations Center › No "Black", "Default", or "Retro" Skins for the New-Look Site?
post #1 of 6
Are those options missing, or am I overlooking them?
post #2 of 6
No retreo and never will be. But black is there, as I am currently using it.
I didn't have to set it, as all "retro" users were switched to black.
post #3 of 6
You can find the darker skin by going to:
My Profile (top tab) --> Edit Account Details (button) --> Scroll down to "Visual Preferences" --> Site Skin: AVS Black
post #4 of 6
Got it, thanks. But.......looks like I'll be sticking with black. The default is just way too bright for my taste.
post #5 of 6
White is too bright and black is too dark. I wish there was more than 2 options.
Mark
post #6 of 6
Mark
During initial testing, the black skin was set up so that it was a little easier to see the posting borders, i.e., know where the posts separate a lot easier than now.
While I really liked the "retro" skin (I was one of the few users), this black skin isn't all that bad. I prefer it over the white.
Can it use some tweaking? Yep. You should have seen it before it went life. There were a few of things that couldn't be read. Fixed before going live.
AIUI, it not an easy task to create a skin.
But hang in there, I do not believe that skin tweaking is done.
  Back to Forum: Forum Operations Center
