AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon AVR 1712 Remote Control Lock On
post #1 of 9
I just purchased a Denon AVR 1712 and the remote control lock is on. I can not find how to turn it off in the manual Any suggestions?
Gear mentioned in this thread:
post #2 of 9
Not sure what you mean by remote control lock?
Press the "amp" button first on the remote if you want to use the remote for the 1712.
post #3 of 9
AFAIK, there is none. Are you referring to the "Setup Lock" feature for the AVR (p. 66)? Otherwise, you can return the remote control to it's default settings (p. 79).
Also note there is a dedicated Denon AVR-XX12 Owner's thread linked in my sig. Review posts 3-6 for some helpful information.
post #4 of 9
Yes I did try that. No matter what button i push, the panel flashes "remote control lock on" to me and the remote does not work
post #5 of 9
You'll likely have to do a microprocessor reset to return it to normal again (p. 96).
post #6 of 9
Ahhhh - that worked! Thank you so much!
post #7 of 9
I have a Denon AVR 1513 and somehow the settings changed and whenever we try to use the remote we receive "REMOTE LOCK: ON" message and nothing works. I checked the owners manual and there is no mention of a remote lock function. One of these posts states to do a microprocessor reset but there is no mention of that either. Any ideas? Thank you.
post #8 of 9
1513 microprocessor reset (p. 54 OM).
post #9 of 9
Thank you. That worked.
