AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Denon 2312 zone 2 wattage out put
post #1 of 8
Gday all, im currently in the process of running the zone 2 of my denon to another amp (thats outside) and from that amp to 2 out door speakers) I like the idea of a seperate amp for volume ctrl without having to go inside.
My question is does zone 2 run the an individual wattage (ie. its a seperate chanel) or does it use power from the main zone and split it.
Anyone know?
post #2 of 8
i think it does...
better off using the preouts?
post #3 of 8
If you are doing that for volume control only then just set up airplay and control it from your phone.
post #4 of 8
Good call in regard to the phone, but im a bit oldschool..lol
But my original Q in regard to zone 2 beeing a sep wattage chanel goes unanswered......
post #5 of 8
no, it is drawing from the same power supply...
post #6 of 8
I think the OP is asking if when using the pre-outs, how does it effect Zone 1, correct OP?
I am not familiar with that AVR, but most AVRs that offer a Zone 2 pre-out, send an un-amplified signal. So if you have a 5.1 AVR at 100WPC and you use the zone 2 pre-outs there is no loss of WPC to the main 5.1 system, aka Zone 1.
Since the Zone 2 pre-outs are unamped, you are doing the right thing to run it to the second amp outside.
The real concern would be making sure that the run from the Zone 2 pre-outs is not too long, and that weather will not have a negative effect on the AVR.
post #7 of 8
TY, that makes sence. And the main AVR will be inside, the outside amp and speakers will be a 2nd hand, so if i get a year out of ill be happy. (will be undercover).
post #8 of 8
In regard to length,,15meters be ok (box to box)?
